The Bow-tie Method
The bow-tie can be used to help simplify risk assessment by allowing one to conceptualise the interaction of causes, controls and consequences of a risk. The following diagram illustrates the process.
Risk Analysis using Bow-Ties[link Point to another website Only the registered members can access]
The steps to undertaking a risk analysis using the bow-tie method are as follows:
- Of all the possible consequences resulting from the risk (these are the yellow boxes above), identify which is the most foreseeable, as opposed to the worst-case
- Identify the consequence level of the most foreseeable consequence
- Identify the likelihood level of the risk occurring and resulting in the consequence identified in Step 1
Example: Kitchen Fire
In this case, we might identify that the most foreseeable consequence of a kitchen fire would be asset destruction. Our analysis would thus be:[link Point to another website Only the registered members can access]
- What is the consequence of asset destruction due to fire?
- What is the likelihood that there will be a fire which causes asset destruction?
By constructing a bow-tie diagram, one can simply see how multiple causes with failed preventative controls result in a risk occurring. If the preparedness controls also fail, the risk will occur and have a negative consequence. Mapping risks using the bow-tie can provide a sound starting point from which to ensure controls are actually addressing the real causes and consequences.
