Results 1 to 5 of 5
Thread: Welder Qualification ?
  1. Welder Qualification ?
    I Have Welder Qualify With
    Material: A106 Gr.B
    Filler Metal : TGS-50 (ER70S-G, A5.18)
    Ask:
    Welder Qualified with Detail Above .they can
    do welding Material :A333 Gr.6
    Fillermetal : TGS-1N (ER70S-G, A5.28)
  3. post removed
  5. Use ASME Section IX.
  6. post removed
  7. Re: Welder Qualification ?
    Hi there, to answer your question I would need additional information, what was the code/standard that you're using, and second how about other essential variable (thickness,position etc)
  1. Welder certificate by EN 287 e 288
    By bigferro in forum Engineering Certificates
    Last Post: 07-16-2014, 02:52 PM
  2. welder qualification
    By nuka in forum Pipeline And Fluid Flow
    Last Post: 02-16-2014, 09:38 AM
  3. Mechanical test for Welder Qualification on barge
    By danidarwis in forum Mechanical Engineering
    Last Post: 05-29-2013, 04:36 AM
  4. Qualify welder
    By umi in forum Mechanical Engineering
    Last Post: 06-12-2011, 10:43 AM
  5. This post for Mr Welder
    By rayito in forum Oil And Gas Process
    Last Post: 10-16-2010, 09:28 PM
