Thread: Qualify welder
    Mar 2011
    Vung Tau, Vietnam
    Qualify welder
    Hi everbody,
    I have a question, I qualify welder follow to ASME IX, with pipe 2"inch, so I can use this welder do welding pipe 3/4 inch is not.
    QW 452.3 ASME IX show that less than 25mm .
    If we follow ASME B36.10 pipe schedules, 3/4 inch = 26.7 mm. So Can I do that right.
    Never Give Up
    View in ASME B36.10 Ed.2004
    Item: 2 SIZE
    The size of all pipe is the nominal IDENTIFIED BY
    pipe size.
    The manufacture of pipe NPS 1 / 8 (DN 6) to NPS 12
    (DN 300), inclusive, is based on a standardized outside
    diameter (OD). This was OD Originally selected so that
    with the standard pipe OD and wall thickness Having a
    That was typical of the period would Have an inside
    diameter (ID) Approximately equal to the nominal size.
    Although there's no such relation Between the existing
    standard thickness - OD and nominal size - These
    nominal sizes and standard ODs continue in the use
    Standard''.''
    The manufacture of pipe NPS 14 (DN 350) and larger
    proceeds on the basis of an OD Corresponding to the
    nominal size.
    Answer: That is if a tube is 3 / 4 it will be considered 3 / 4 or 20mm round off because the asme + 0.5
    (Ie 3 / 4 is accurate: 19.05000, 20.00000 rounded)
    table as an ASME B31.10 Ed.2004
    Table 1 Weights and Dimensions of Welded and Seamless Wrought Steel Pipe
    NPS = 3 / 4
    Outside Diameter = 1.05 in
    Calculation: 1.05 x 25.4 = 26.67mm (ie 26.67 mm is the external diameter of the tube)
    Welder qualification: According to ASME IX Ed.2010
    As in QW 416 Welding Variables (Performance welder)
    The diameter of the tube in the welding processes: SMAW, SAW, GMAW, FCAW, GTAW and PAW. It is an essential variable.
    See QW 403.16
    QW-403.16 A change in the pipe diameter Beyond the
    range qualified in QW-452, except the Permitted Otherwise
    in QW-303.1, QW-303.2, QW-381.1 (c), or QW-382 (c).
    If your case goes to joint top notch "V" You will use the QW 452.3
    QW 452.3
    If the welder Use your qualification in the real value of:
    1 "in (25mm) or less your track will be qualified:
    diameter (external) = minimum size qualified soldier (an "in-25mm)
    diameter (external) = maximum qualified Unlimited
    Example: In your case will be so.
    REAL VALUES
    Diameter (external) qualiicado least 3 / 4 (26.67)
    RANGE QUALIFIED
    Diameter = Min Size Max Diameter = welded Unlimited
    You must qualify your welder in tube 3 / 4 in.
    which can weld any diameter.
  1. Welder certificate by EN 287 e 288
    By bigferro in forum Engineering Certificates
    Last Post: 07-16-2014, 02:52 PM
  2. Qualify tack welder piping follow ASME IX
    By umi in forum Mechanical Engineering
    Last Post: 07-08-2011, 09:23 AM
  3. Requirements to Qualify IBR welder.
    By ify09 in forum Pipeline And Fluid Flow
    Last Post: 07-05-2011, 12:17 PM
  4. Article: Qualify welder
    By umi in forum Home Articles
    Last Post: 06-18-2011, 10:37 PM
