Results 1 to 5 of 5
Thread: Area calculation in Petrel
    Nov 2008
    Australia
    Received the following message, and thought others might be interested as well;
    Please I need your Help.
    I have a 3D Grid data in Petrel software.
    I need from the information of the Grid the Reservoir Area.
    how can I find the reservoir area?
    if my information of the grid is i j k = volume.
    I hope your help
    Unfortunately, it is not a simple button click, and while there might be more elegant methods, the following should work;
    1. Start with your top reservoir surface from the Input tab. If you do not have a surface (ie you imported a simulation grid as the starting point), then you'll need to make a surface from the top layer
    2. Right click - Properties on the surface - Operations
    3. Select Surface operations, and create intersection with plane - type in the OWC/GWC you have (remember, Petrel depth is negative) - run
    4. this should create a new polygon set - display the polygon set and ensure it is closed, if not, close it
    5. Under Properties - Operations - Area & Length you should be able to pull the Area and length of the polygon in your project units
    As an alternative, you can simply draw a polygon around the area of interest and find the properties of it.
    VM
    Thanks a lot
  5. Re: Area calculation in Petrel
    Petrel 2010.1 c=r=a=c=k required in return abaliable , Peterel2009.1,Ki-n-g-do-m,Opendtect,interactive petrophysics,petromod
  6. Re: Area calculation in Petrel
    Hello,
    I need petrel 2010.1 c******-c-k only or Geoframe or , in return i have 1. Opendtect 4.2 license 2. petrel 2009 3.K-in-g-dom 4. interactive petrophysics 5.petromod 7.rep for reserve calculation 8. Hampson Russell . contect me greathelp2@gmail.com
  7. Re: Area calculation in Petrel
    i want is this book
  1. atex calculation area
    By nmerzak in forum Safety And Environment
    Last Post: 05-16-2013, 11:19 PM
  2. Calculation of inflow area for bilinear flow
    By pet_spec in forum Reservoir
    Last Post: 05-02-2013, 03:17 PM
  3. Article: Area calculation in Petrel
    By vinomarky in forum Home Articles
    Last Post: 05-01-2012, 12:41 AM
  4. Article: Area calculation in Petrel
    Last Post: 12-28-2011, 08:15 AM
