Thread: Procedure qualification
  1. Unhappy Procedure qualification
    Can some1 please expain me the para 403.5 of ASME IX , for P & group no qaulification.
    if we do the test with P1 G1 to P1 G1 is tht qaulify for P1 G1 to P1 G2 material is tht so?
    or is it valid whn impact is done ?
    im not able to interprate the code para properly . pls help
    The procedure is qualified to weld with the same P no. and with same / different Group no. if the construction does not required impact testing.
  5. QW-403.5
    In addition, when base metals of two different P-Number Group Number combinations are qualified using a single test coupon, that coupon qualifies the welding of
    those two P-Number Group Numbers to themselves as well as to each other using the variables qualified.
    This variable does not apply when impact testing of the heat-affected zone is not required by other Sections.
    Interpretations:
    Subject: Section IX, QW-403.5
    A welding procedure qualification is made using the following combination of base metals P-No.1 Gr-No.1 to P-No.1 Gr.2. The client specification requires impact testing only for P-No.1 Gr-No.1 materials
    (in the weld metal and heat affected zone). For procedure qualification purposes,is the impact testing only required in the weld metal and in the heat affected zone on the P-No.1 Gr-No.1 base metal side?
    Reply: Impact tests are conducted when required by other ASME Sections.
    Does the procedure qualification test coupon qualify the welding of P-No.1 Gr-No.1 base metal to any other P-No.1 base metal not to be impact tested using the variables qualified?
    Reply: Yes
    Interpretation: VIII-1-95-06
    Subject: Section VIII D1
    Question: A procedure qualification test consisting of P-No.1 Group No.1 material welded to P-No.1 Group No.2 material meets the impact toughness criteria for the weld and heat affected
    zones under UG-84(h)(2)(a). Can this test plate support the production welding of P-No.1 Group No.1 to P-No.1 Group No.1, P-No.1 Group No.2 to P-No.1 Group No.2, and P-No.1 Group No.1 to
    P-No.1 Group No.2 materials, assuming all other applicable requirements of the Code have been met?
    Reply: Yes.
  6. thanks guys for your help. Srry for the late reply as i dun hav the net connection atm
  1. welder qualification
    By nuka in forum Pipeline And Fluid Flow
    Last Post: 02-16-2014, 09:38 AM
  2. ISO standards : TC 135/SC7 - Personnel qualification
    Last Post: 03-21-2012, 02:31 PM
  3. Welder Qualification ?
    By yamada326 in forum Petroleum Club
    Last Post: 02-09-2012, 06:21 PM
  4. Sec IX Buttering Qualification Welding Procedure???
    By sooeey2u in forum Petrochemical
    Last Post: 02-03-2011, 10:54 PM
  5. Replies: 0
    Last Post: 07-29-2010, 10:49 AM
