Well if you have well test data, for example build-up, try to interpret it. If the time of build-up was enough, you probably see some faults or maybe all of them. Moreover, there is a method to estimate well drainage area from build-up when time wasn’t sufficient to see any boundaries - [link Point to another website Only the registered members can access]
The results would be the same as for simplified geological model, during interpretation of build-up you also assume constant k and h and you receive drainage area as a radial or linear (in case of faults) distance from the well.
