Downhole Tubing
Pipe description
Pressure range -Max to 3000 psi (21MPa)
Resin: - Aromatic Amine Cured Epoxy
Reinforcement materials- Fiberglass
Joining Systems - API 5B 8rd, Threaded and Coupled
Joint Length: 9.1 meter Nominal, API
Temperature - Up to 93.3° C (200° F)
Diameter – 40mm to 200mm
Fittings - A variety of filament wound API 5B threaded
Nipples and Couplings
Features
Good mechanical and physical performance
Corrosion control to CO, H S & salt water
High flow efficiency
Easily installation
Excellent Logging Characteristics
Long service life
Applications
Observation well casing
Disposal or Injection Tubing to depths of 3000meter
Production Tubing
Chemical waste disposal
Open Hole Casing, Zone or to Surface
