GRE Pipe - Aromatic Amine Cured Epoxy High Pressure Fiberglass Pipe
[link Point to another website Only the registered members can access] Diameter ranges DN40-DN600 (1 1/2”-24”)
Pressure rating range 3.5Mpa—25Mpa
The long-term working temperature ≤93.3℃(200℉)
The maximum temperature 135℃(275℉)
The minimum temperature ≥-35℃(-31℉)
Length the nominal length of the pipes is divided into four kinds according to the pipe. (9.14, 8.8, 8.6, 8.2)
Manufacturing techniques with design set linear and thickness, filament winding control by computer and curing
Resin System Amine Cured Epoxy
Raw materials Epoxy Resin, Excellent fiberglass, glass fiber roving's
Standard: API Spec 15HR
Fittings All of the standard FRP fittings are matched well with the original pipes. Most of the fittings are produced by filament winding process. all fittings should be ordered as per thread specification and design pressure.
Connection API screw thread seal with aqua seal connection of 8 round or 10 round
Kits the sealant is packed into kits, which include brushes, plastic gloves, slab rubber etc. It could be used in the field conveniently.
Application:
Injection and delivery pipeline
Crude oil
Potable water
Brine transport pipeline
Oilfield sewage, chemical sewage and wastewater process pipeline
Fire water pipeline
Storage tank connector
Polymer solution transmission pipeline
Petrochemical process pipeline
Geothermal pipes
Slotted liner and sieve vessels
Natural gas
CO2 or H2S
CO2 or H2S gathering and transport lines
Other liquids processing pipeline
Advantages:
Excellent chemical resistance property,
Able to withstand high pressure
Higher transportation efficiency
Light weight-easy to install
Designable electrical property
Lower abrasion coefficient
Able to connect with steel pipe directly
Smoothly inner wall, no scaling, no waxing, not prone to clogged
Longer service life that is 4 to 5 times compare to steel pipe(about 20 years)
Low maintenance cost
