Hello,
has anyone an idea if it is possible to run a bridge plug on E-Line, which has to be set in 5", trough a 2 3/8" tubing (1,901" drift). I had a look in some product brochures, but can´t find something.
Hello,
Hi- the World Oil Tools inflate packers, see catalogue below, might do it- but they are typically run on Coil. Even then you don't get much differential pressure across it and it will pay to dump some cement on it if you need to hold much pressure.
