Results 1 to 8 of 8
Thread: GOST & PB codes
  1. GOST & PB codes
    I need information oon following codes.
    GOST 51273-99
    PB 03-576-03
    PB 03-584-03
    I want to check the requirement of radiography on weld either 10% or 100% on flat head of cylindrical pressure vessels as per Rostechnadzor code. Basically its designed undert section VIII but it will be installed in the region where local Rostechnadzor codes apply.
    Am too much confused abut this code. Any info on Rostechnadzor code will be much needfull for me. Thanks in advance.
    Go to Skype: yuriyuri702. I can send some Russian stds c local standards (Gazprom, Transneft, etc)
  5. Thanks. I sent you detailed mail regarding this. Please reply.
    Hi, Thanks. following are the details with what I am dealing with.
    We are manufacturing one cylindrical vesse who has flat head on both sides. As dia of flat head is 4.5m, we are using two plates, so butt joint is there on head. Vessel is designed as per ASME section VIII div I which shows radiography as NILL. Third party involved in inspection is Lloyd's Register. Loyd's insisting us on 100% radiography for this Butt joint, giving reason that if taken 10% radiography then thickness of flat head (20mm) is not enough as per UG34 of section VIII div 1. But this code is for unstayed flat head. UG47 is for stayed flat head. We have symmetrical stay supports for head. But UG47 formula for thickness of flat head dont take care of joint efficiency (E). This is one problem.
    second problem is that, as this vessel will be installed in russian area then there Rostechnadzo regulatories comes into play. Last time when we supplied plant there then these authorities taken radiography on site to reverse check this. One of our engineer who is now in Moscow tell us that we need 100% radiography on this butt joint. I want to check which rule/code/standard make it 100% because they are also not giving as code number for this.
    If there is requirement of code then surely we must follow it, but if there are exclusions for this then we must take advantage of that to reduce the cost.
    So can you please guide me which regulation / code applies to our case & if possible can you please mail me that code.
    Thanks in advance.
  6. TO ADMINISTRATOR
    Sir,
    when i click on "what is new" & "new posts" error message is coming for theatwo days. can you please look into this issue to sort out the existing problem at the eraliest?
    Thanks in advance
    could u plz shrae GOST for piping design?
    tanx in advance
  9. Re: GOST & PB codes
    Gostperevod.com - Russian GOST and SNIP standards in English
    Gostperevod.com related to the normative and technical documentation, codes and standards, law and orders, resolutions of Russian Federation and CIS in English.
    PUE, KMK, SHNK, O’z DSt, TSt, STH, GOST, GOST R, GN, MI, MU, NPB, NP, OND, ONTP, OST, PB, PNAE, IPA, POT, PPB, PR, RD, RDS, RMU, RTM, SanPin, SN, SO, SP, STO, TI, TOI, TU, VNTP, VPPB, VRD, VSN already translated into English.
    Gostperevod.com is your source for Russian industry codes and standards both in Russian language and translated into English. We suggest the most comprehensive database of Russian Regulatory and Legislative Documents, Standards, Regulations, Norms, Codes in English. Our own qualified staff of technical translators can offer high quality translations of standards, codes and regulations. We guarantee that the standards and translations from our site include all changes which are adopted at the moment.
    Our collection includes GOST and GOST R standards (national standards of the Russian Federation) as well as Russian and CIS countries standards and technical regulations for all major industries, including Building Codes (SNiP, SN, GESN, KMK, SHNK), Industry Codes and Safety Rules (RD, PB, TSt), Sanitation Regulations (SanPiN, GN, SP), Fire Codes (NPB, PPB), norms, instructions, procedures, cost estimate standards, Russian federal and regional legislations and many others.
    Please request the types you need and our consultants will help you to find the documents.
    One of our main advantages is that we offer our customers not only accurate translations of normative documents but check and update the texts with all necessary amendments, supplements and revisions thus providing the up-to-date versions.
    GOSTPEREVOD (TRACE LLC)
    22, Boytsovaya Street, 107150, MOSCOW, Russian Federation
    Phone: +998909902077
    E-mail: info@gostperevod.com
    Web-site:
    [link Point to another website Only the registered members can access] Follow us on Twitter:
    [link Point to another website Only the registered members can access] Facebook:
  10. Re: GOST & PB codes
    Web-site:
  11. Re: GOST & PB codes
    Web-site:
  1. Russian (GOST) standards
    By Vladiana in forum Mechanical Engineering
    Last Post: 02-15-2018, 09:08 PM
  2. ASME B16.47 and GOST R 52630
    By AMinati in forum Mechanical Engineering
    Last Post: 11-15-2016, 08:40 PM
  3. Gost required
    By PVHE in forum Mechanical Engineering
    Last Post: 11-03-2014, 10:52 PM
  4. gost standard for refinerry
    By dilema_pg in forum Petroleum Refining
    Last Post: 11-03-2014, 10:29 PM
  5. I need gost!!!!
    By barbara in forum Oil And Gas Process
    Last Post: 11-03-2014, 10:21 PM
