Page 1 of 2 1 2 LastLast
Results 1 to 12 of 20
Thread: Russian (GOST) standards
    I need some Russian standards, in English and the last edition if is possible. Someone help me?
    GOST 12.2.063, GOST 12.2.003, GOST 356, GOST 9544, GOST 21345, Gost 5762
    Thank you.
    Quote Originally Posted by Vladiana View Post
    Thank you.
    Are you sure that these standards in English exist ?
    I can give you www for these standards in Russian edition.
    No, 0501, I am not sure. It's OK in Russian edition
    Oct 2008
    The Netherlands
    Blog Entries
    14
    Thank you.
    I might have some about GOSTs about piping or vessels in english , also some SNIPs about structural ...
    but a question =
    Regarding the GOSTs , to which discipline or subject are there related ???
    These standards are about valves.(discipline: piping ) I need them in engkish or in russian
    Thank you
    Oct 2008
    The Netherlands
    Blog Entries
    14
    1/ Normally we try to use valves according B16.34 and API 6D which are all with flanges B16.5
    2/ to my knowledge russian standard for valves are based on PN and not #pounds
    3/ Also in oil and gas the russian start with line classification , and then valve definition will follow (seat type , leakage ....)
    4/ I have attached a GOST ? who knows , this might be helpfull
    I was placed links for these GOSTs (in Russian) in the thread yesterday, but it is not appeared.
    While placing my reply, was appeared message that it will reviewed moderator and then will be placed into thread...
    does anybody have any GOSTs in oil, gas, chemical, petrochemical and related industries would be good in Russian or English, please??
    Vladiana, I have send www for GOSTs as private message for you, read, please
  14. Quote Originally Posted by 0501 View Post
    Thank you 0501. I read the message.
  16. #12
    VSN_011-88 Main Flowline Pipeline Construction Bore Cleaning and Testing-RUSSIAN CODE
    Hi
    DO u have
    i need VSN_011-88 standard for Main Flowline Pipeline Construction Bore Cleaning and Testing....IN ENGLISH
    urgently
  1. Help :Russian Standards for Pipeline (English Version)
    By cindy_dianita in forum Pipeline And Fluid Flow
    Last Post: 01-15-2016, 10:51 AM
  2. Gost required
    By PVHE in forum Mechanical Engineering
    Last Post: 11-03-2014, 10:52 PM
  3. Replies: 6
    Last Post: 11-03-2014, 10:27 PM
  4. I need gost!!!!
    By barbara in forum Oil And Gas Process
    Last Post: 11-03-2014, 10:21 PM
  5. ASME Standards and Coades in Russian
    By beznosik in forum Mechanical Engineering
    Last Post: 10-02-2013, 08:28 PM
