Thread: SATNUM, relative permeabilities other properties for each facies
  1. SATNUM, relative permeabilities other properties for each facies
    Hello,
    Can anyone tell me how is it possible to assign rel perms for each facies? What should be done with shales, since they also present as a separate facies.
    Thanks.
    Dev_r
    Nov 2008
    Australia
    Create a SATNUM array, with different integer values for each of the facies you believe has a different rel perm curve. If you define (for example) SATNUM valules of 1-5 in your model, you then need to specify 5 sets of rel perm tables
    Regarding shales, just assign them as one of your poorer facies - it will be pretty well irrelevant anyway as their perm should be very low, and their overall saturation is unlikely to change from the initial saturation to any significant degree - you may want to seriously consider assigning their NTG = 0 or PORO = 0 anyway to speed up simulation unless of course vertical flow across the shales is important in your model
  1. Replies: 2
    Last Post: 03-10-2017, 11:02 AM
  2. How can I make a facies model on petrel?
    By metalz in forum Reservoir
    Last Post: 08-16-2013, 05:21 PM
  3. How can I make a facies model on petrel?
    Last Post: 06-15-2013, 09:00 AM
  4. facies paper
    By michau83 in forum Geology & Exploration
    Last Post: 02-08-2010, 05:22 PM
  5. Facies models
    By geofab81 in forum Geology & Exploration
    Last Post: 08-18-2009, 05:29 AM
