Results 1 to 9 of 9
Thread: Can I estimate initial condensate rate if I know gas composition?
  1. Question Can I estimate initial condensate rate if I know gas composition?
    I have a gas condensate field with following composition:
    How can I estimate condensate rate (bbl condensate / milion gas cubic meters)?
    No Components Yi
    1 CO2 0.019679
    2 N2 0.008827
    3 C1 0.75981
    4 C2 0.096321
    5 C3 0.050592
    6 I-C4 0.00899
    7 N-C4 0.013479
    8 I-C5 0.007099
    9 N-C5 0.004249
    10 C6 0.003772
    11 C7-C9 0.012616
    12 C10-C13 0.006503
    13 C14-C19 0.004592
    14 C20-C29 0.00264
    15 C30+ 0.000829
    Sum 0.999998
    Dec 2007
    Novi Sad, Serbia
    You need lab. separator test...
  5. should be possible without lab
    As far as I know C3,C4 components are for LPG and C5+ for condensate.
    If you have concentration of each component as I provided should be some analytical / empirical formulas that could relate those concentrations with condensate and LPG rate.
    Initial condensate
    What kind of physical system condition (P,T) for your raw material...maybe u can simulate it with hysys for steady state...CMIIW
    You need the overall mass or volumetric flowrate with T&P in order to be able to calc. whatever!
  9. Question Eclipse PVTI
    Simulations means a static model.
    Eclipse PVTI could be helpful?
    (no experience with this tool)
    If an equation of state is build in PVTI could be simulated on a simple sector model with E300?
    Could you this way obtain some estimated CGR vs pressure?
    Nov 2008
    Australia
    You should be able to get a reasonable approximation by assuming all your C6+ drops out as condensate. Just calc the liquid volume equating to this fraction, along with the gas shrinkage due to condensate drop out
  11. use a flash calculation e.g. HYSYS with peng and robinson. Flash at standard conditions like 15 C & 0 barg. Find out the ratio. To be more precise, you can assume a separator pressure & temperature wrt what kind of field/operation/stage you will run.
    catapam,
    I'm inexperienced, bu I have just one suggestion: check out Petroleum Experts' IPM software, namely PVTp and Prosper. Go through the "EOS calibration of a condensate sample using PVTp" tutorial in PVTp and find out the data you need to do a full fluid characterization that would allow you to generate a phase envelope (P-T diagram - allows you to derive CGR vs pressure). When you get the list, you can make recommendations to your boss to acquire the required data. When you get the data, go through the PVTp program and get your EOS fluid model. Go to Prosper and build your completion model and import the EOS fluid model into Prosper. Set up your sensitivity variables (CGR, WGR, FTHP) and run your lift curve calculations and then plot your well performance curve (IPR vs VLP), then read off the oil (condensate) rate at the intersection. Tell me if I'm wrong, I'm not sure.
    Markus L.
  1. specification of initial saturations
    By walead in forum Reservoir
    Last Post: 08-09-2015, 01:13 PM
  2. Replies: 4
    Last Post: 09-05-2013, 10:30 AM
  3. Replies: 4
    Last Post: 08-24-2011, 06:51 PM
  4. Offshore Condensate system design, Condensate design
    By Hiren in forum Oil And Gas Process
    Last Post: 07-23-2010, 08:25 PM
  5. Initial saturation
    By dipak_m in forum Reservoir
    Last Post: 04-21-2010, 05:12 AM
