I have gas composition and I need to estimate the dew point.
Any advice?
Thank you.
Any advice?
Thank you.
Not sure if it is the 'best' one, but found this;
Hi..
Yuo can use "A correlation of Dewpoint Pressure with fluid composition and Temperature" Nemeth, Kennedy.
see GPSA or API TDB for reliable charts and procedures to estimate dew points,
to get accurate results at high pressures however I would suggest to use a software, see for example
"http://www.prode.com/en/dewpointnaturalgashydrocarbons.htm"
