Thread: how to generate surfaces using only log data in petral.
    i want to generate surfaces using log data since i dont have seismic.can somebody help me.
  3. yes you can ( but prefer to uses sesmic map) to decrease the uncertinity
    1-frist make the coorelation
    2-then pick the formation tops
    3-then open make edit surface in utility process
    4-use the formation tops as main input
    thanks, i have a problem whenever i am importing surfaces to model they are merging where as in input data they remains separated why it is so.
  6. please explain more to understand the problem
  1. Characterization Of Corrosion Products On Steel Surfaces
    By BornToSin in forum Materials Science &Corrosion
    Last Post: 05-24-2011, 06:50 PM
  2. facing problem in petral
    By amitkannojia in forum Reservoir
    Last Post: 04-12-2011, 08:36 PM
  3. petral data loading
    Last Post: 03-02-2011, 02:40 PM
  4. How to Generate Relative Permeability Curve Data
    By Feldy Riza in forum Reservoir
    Last Post: 10-22-2010, 08:53 AM
