Practical Centrifugal Pumps
Practical Centrifugal Pumps is a comprehensive guide to pump construction, application, operation, maintenance and management issues. Coverage includes pump classifications, types and criteria for selection, as well as practical information on the use of pumps, such as how to read pump curves and cross reference. Throughout the book the focus is on best practice and developing the skills and knowledge required to recognise and solve pump problems in a structured and confident manner
HVAC Pump Handbook, Second Edition
First published in 1996, McGraw-Hill's renowned HVAC Pump Handbook set a new standard for excellence in the field. Now completely updated, the Second Edition equips HVAC designers, engineers, and technicians with concrete methods for achieving efficient operation in pumps for HVAC and water systems using the latest digital electronic technologies. Filled with case studies, current codes, and solved problems, the reference covers HVAC pumps and their performance…the basics of HVAC water systems…pumps for open and closed HVAC cooling systems…pumps for HVAC hot water systems…HVAC pump instrumentation and testing...and much more. With the help of this revised Second Edition, HVAC professionals can:
pw :shouman
Pump User's Handbook:
This unique, experience-based explains just how and why the best-of-class pump users consistently achieve superior run lengths, low maintenance expenditures, and unexcelled safety and reliability. It conveys in detail what facilities must do to rapidly accomplish best-of-class performance and low life cycle cost. Implementing the guidelines found in this book will allow a plant to move from yesterday's unprofitable and costly repair focus to tomorrow's necessary reliability focus. Simply put, xplains exactly what needs to be done to progress from a one, two or three-year pump MTBF plant to join the leading money-making facilities that achieve a demonstrated pump MTBF of 8.6 years
Progressing Cavity pumps, Downhole Pumps and Mudmotors
Written by one of the world's foremost authorities and instructors on pumps, this first volume in Gulf Publishing Company's new Gulf Pump Guides series covers the design, application and troubleshooting for progressing cavity pumps, downhole pumps and mudmotors. There is no other volume offering such a comprehensive, easy-to-understand and hands-on coverage of these types of pumps. As they become more and more widely used in the petrochemical industry, and other industries, knowledge of their design and application will become increasingly more important for the engineer.
Liquid Ring Vacuum Pumps, Compressors and Systems
ISBN : 3527312498
Author: Helmut Bannwarth
Publisher: John Wiley & Sons
(May 6, 2005)
Pump User's Handbook: Life Extension, 2nd Edition
By Heinz P. Bloch, Allan R. Budris
This unique, experience-based explains just how and why the best-of-class pump users consistently achieve superior run lengths, low maintenance expenditures, and unexcelled safety and reliability. It conveys in detail what facilities must do to rapidly accomplish best-of-class performance and low life cycle cost. Implementing the guidelines found in this book will allow a plant to move from yesterday's unprofitable and costly repair focus to tomorrow's necessary reliability focus. Simply put, explains exactly what needs to be done to progress from a one, two or three-year pump MTBF plant to join the leading money-making facilities that achieve a demonstrated pump MTBF of 8.6 years
Slurry Transport Using Centrifugal Pumps
Vast tonnages of solid-liquid mixtures are pumped every year in dredging operations, mining and waste-disposal applications. Most of these systems are centrifugal pumps, and the resolution of problems encountered in slurry pumping requires both detailed scientific knowledge and judgment derived from practical experience.
For many years the combination of up-to-date analysis and hands-on experimentation has been provided to interested engineers in a short course based at the GIW Hydraulic Laboratory. The lecturers in this course, who represent a broad background of international expertise, have prepared this widely-recognized, Slurry Transport Using Centrifugal Pumps, Third Edition.
This unique ************ is logically divided into two sections: the first part of the book concentrates on the behaviors of various sorts of slurry flow, and the second part deals with the behavior of centrifugal pumps handling slurries, and with how pumps and pipelines interact as a system.
Slurry Transport Using Centrifugal Pumps, Third Edition also includes:
New material on both non-Newtonian flows and slurries of granular particles.
New information on pump wear, solids effect, and system operation.
Updated and completely new material on pump selection and environmental aspects
Worked examples and case studies that stress practical applications
Slurry Transport Using Centrifugal Pumps, Third Edition, will be of interest to all engineers and technologists involved in the large-scale transportation of slurries.
rar-pass = TQN0387232621
part 1
part 2
part 3
Hydrodynamics of Pumps
Focuses on special problems and design issues associated with pumps: the potential for cavitation, the damage and vibration problems which result from cavitation, and the possibility of large unsteady flows and forces on the machine. The book provides a coherent and unified treatment of the hydrodynamics of pumps with an emphasis on the underlying physical phenomena. An important reference for engineers and scientists, it is also appropriate for graduate courses in turbomachinery.
Engineering - Centrifugal and Rotary Pumps - Fundamentals with Applications
Troubleshooting Centrifugal Pumps and their Systems
Hardbound. Pumps are fine until they malfunction or break down. When that happens, the first priority is to get the pump functioning again and to keep 'down time' to a minimum. Many problems can be diagnosed and rectified using a combination of knowledge and experience, the latter coming over time. This book, written by a very experienced engineer, guides the reader through diagnostic pathways leading to logical explanations for the malfunctions and their correction.
Pump Characteristics and Applications
This hands-on reference offers a practical introduction to pumps and provides the tools necessary to select, size, operate, and maintain pumps properly. It highlights the interrelatedness of pump engineering from system and piping design to installation and startup. This updated second edition expands on many subjects introduced in the first edition and also provides new in-depth discussion of pump couplings, o-rings, motors, variable frequency drives, pump life-cycle cost, corrosion, and pump minimum flow. Written by an acclaimed expert in the field, Pump Characteristics and Applications, Second Edition is an invaluable day-to-day reference for mechanical, civil, chemical, industrial, design, plant, project, and systems engineers; engineering supervisors; maintenance technicians; and plant operators. It is also an excellent upper-level undergraduate and graduate students in departments of mechanical engineering, mechanical engineering technology, or engineering technology. About the Author Michael W. Volk, P.E., is President of Volk & Associates, Inc., Oakland, California ([link Point to another website Only the registered members can access]
University of Southern California, Los Angeles
password = forfulltqnmembers2006
Handbook of Pumps and Pumping: Pumping Manual International
Written by an experienced engineer, this book contains practical information on all aspects of pumps including classifications, materials, seals, installation, commissioning and maintenance. In addition you will find essential information on units, manufacturers and suppliers worldwide, providing a unique reference for your desk, R&D lab, maintenance shop or library.
* Includes maintenance techniques, helping you get the optimal performance out of your pump and reducing maintenance costs
* Will help you to understand seals, couplings and ancillary equipment, ensuring systems are set up properly to save time and money
* Provides useful contacts for manufacturers and suppliers who specialise in pumps, pumping and ancillary equipment
Practical Introduction to Pumping Technology
Here is a convenient, concise reference book for pump users, application engineers, technicians, and buyers. It contains, in condensed form, valuable information on selecting centrifugal and positive-displacement pumps for given applications, creating the necessary aplication, choosing equipment manufacturers, and checking vendor data. You will find a complete explanation of the types of pumps and the terms and parameters used in pump applications. This book outlines the data required by the client, engineer, and buyer to obtain a comprehensive quote
Forsthoffer's Rotating Equipment Handbooks, Vol. 2: Pumps
Over recent years there have been substantial changes in those industries which are concerned with the design, purchase and use of special purpose (ie critical, high-revenue) rotating equipment. Key personnel have been the victims of early retirement or have moved to other industries: contractors and end-users have reduced their technical staff and consequently have to learn complex material 'from scratch'. As a result, many companies are finding that they are devoting unnecessary man hours to the discovery and explanation of basic principles, and having to explain these to clients who should already be aware of them. In addition, the lack of understanding by contractors and users of equipment characteristics and operating systems often results in a 'wrong fit' and a costly reliability problem.
Forsthoffer's Rotating Equipment Handbooks: Pumps presents the operation of pumps in a process system, (using the concept of pump required and produced head) pump selection for cost-effective maximum reliability, eliminating hydraulic disturbances in the design and field operation
phases, control and protection, practical component monitoring of performance, bearing, seal and auxiliary system condition to assure optimum pump safety and reliability.
Forsthoffer's Rotating Equipment Handbook: Pumps is the second title in the five volume set. The volumes are: 1. Fundamentals of Rotaing Equipment; 2. Pumps; 3. Compressors; 4. Auxiliary Systems; 5. Reliability Optimization through Component Condition Monitoring and Root Cause Analysis'.
* One of a five volume set which is the distillation of many years of on-site training by a well-known US Engineer who also operates in the Middle East.
* A Practical book written in a succinct style and well illustrated throughout
or
or
Pump Handbook 3rd Edition
Author: Igor J. Karassik Joseph P. Messina Paul Cooper Charles C. Heald
Publisher: McGraw-Hill Professional
Worldwide developments in pump theory, design and applications have continued to
emerge, and these have begun to affect the outlook of pump engineers and users to such
an extent that a third edition has become overdue. Pumps have continued to grow in size,
speed, and energy level, revealing new problems that are being addressed by innovative
materials and mechanical and hydraulic design approaches. Environmental pressures
have increased, and these can and are being responded to by the creative attention of
pump engineers and users. After all, the engineer is trained to solve problems, employing
techniques that reflect knowledge of physical phenomena in the world around us. All of
this has led the current authors to respond by adding new sections and by revising most
of the others as would be appropriate in addressing these developments. Specifically the
following changes should be noted.
Centrifugal pump theory, in the rewritten Section 2.1, proceeds from the basic governing
fluid mechanics to the rationale that underlies the fundamental geometry and performance
of these machines—while maintaining the concrete illustrations of design
examples. A new subsection on high-energy pumps is included.
An update has been made to Section 2.2.1 on major components of centrifugal pumps.
Section 2.3.1 on centrifugal pump general performance characteristics has been
Centrifugal Pumps: Design and Application, Second Edition
Centrifugal and Rotary Pumps: Fundamentals with Applications
Centrifugal and Rotary Pumps offers both professionals and students a concise reference detailing the design, performance, and principles of operation of the different pumps types defined by the Hydraulic Institute. From historical background to the latest trends and technological developments, the author focuses on information with real-world practicality and techniques you can implement immediately.Beginning with the fundamentals, the ************ then shifts to real field cases that address applications, pumpage, system interaction, reliability, failure analysis, and practical solutions. By including specification parameters and criteria for the application of various pumps, this comprehensive book provides necessary and timely material that plant engineers, maintenance staff, operators can use and share with colleagues
Enjoy.
