hi all,
anybody have a calculation sample of legs during the hydraulic pressure test or can help me with that?
thaks in advice
hi all,
thaks in advice
Thank you!
I'm doing this in PV but now, but I have more questions ....
In calculating of the maximum shear at top of one leg
- Which means "itot" and how is it calculated?
In calculating of the axial compression, Leg futhest from NA
- Which means "Nlegm" and how is it calculated?
- Which means "Rn" and how is it calculated?
In calculating of the allowable axial comp. For the selected leg
- Which means "kl/r" and "Fy" and how is it calculated?
In AISC check
- Which means "Spex" and "Sb" how is it calculated?
I'm trying to do as you said but the result of the equations of the report of PVELITE not coincide with the manual calculation!What can be happening?
Nobody has a spreadsheet for this type of situation? Or formulas to apply. ...
It is an urgent situation. ...
