As'salam'u Alikum,
Can someone give technical suggestions/arguments, on the provision of "Carbon Dioxide Gas Suppression System" for an Explosive Facility with Torpoedo's and Warheads in it?? Will the System Prove to work???
What I think, Gas suppression system is essentially a “one-shot”fire protection system. The system can only be used to suppress a fire "once" within a short period of time. The gas suppressing agent cylinders will have to be replaced before the system can be considered back on-line or we have to provide same Capacity Duty Cylinders (doubling the agent costs).
This means that, if the source isn't removed, the fault that caused the fire in the first place could again cause another fire to be ignited. When this occurs, the gas suppression system will not be able to be activated since a replacement cylinder will take a while to be replaced unless duty cylinders are provided!
What protection system can be installed other than the Gas Suppression System???
Wishing all of you a very blessed EID'ul Fitar!
Best Regards,
P.S. Please remember the Pakistan Flood Victims in your EID and PrayersSearch youtube for the destruction the flood has certainly caused!
