How I display average reservoir property (like porosity) of all layers in Petrel?
Double click on property - select Operations - Make map from property - Make average map - you can give it a surface as well if you like (not required), if you want to visualize it in 3D with your model.
Similarly, you could choose;
1. Volume height map operation to generate HCPV maps from calculated (1-Sw)*Volume()*PORO*NTG property or
2. Make net map operation to generate kh maps from PERM property
Last edited by vinomarky; 09-08-2010 at 01:50 AM. Reason: Corrected the HCPV operation for clarity
Thanks so much Vinomarky. I like it.
