Thread: Pipe thickness
  1. Pipe thickness
    Code ASME B31.3 only gives formula for thickness calculation under internal pressure ...... what if external pressure is exerting on piping(e.g under sea piping where external pressure of water is applicable .....furthermore which code will be applicable...)...?
  3. Faisal,
    while ASME B31.4 and 31.8 can be used I recommend that you review DNV OS-F101 Subsea Pipeline Systems. In some cases it is the installation of the system which is the controlling case (i.e. buckling). You can download it at
    [link Point to another website Only the registered members can access] Regards
  5. Re: Pipe thickness
    faisal99
    Find attached the ASME B31.3 (Process Piping) approach regarding pipe wall thickness calculation under external pressure:
    304.1.3 Straight Pipe Under External Pressure. To
    determine wall thickness and stiffening requirements
    for straight pipe under external pressure, the procedure
    outlined in the BPV Code, Section VIII, Division 1, UG-28
    through UG-30 shall be followed, using as the design
    length, L, the running centerline length between any
    two sections stiffened in accordance with UG-29. As an
    exception, for pipe with Do/t < 10, the value of S to be
    used in determining Pa2 shall be the lesser of the following
    values for pipe material at design temperature:
    (a) 1.5 times the stress value from Table A-1 of this
    Code, or
    (b) 0.9 times the yield strength tabulated in Section
    II, Part D, Table Y-1 for materials listed therein
    (The symbol Do in Section VIII is equivalent to D in this
    Code.)
    I hope this helps... at least a little (as guidence)
  1. Pipe wall thickness as per EN 13480-3
    By pico5892 in forum Engineering Spreadsheets & Presentations
    Last Post: 05-09-2025, 08:40 PM
  2. Pipe Thickness Calculation
    By jonas in forum Pipeline And Fluid Flow
    Last Post: 08-03-2012, 01:25 PM
  3. Thickness gauging of Pipe
    Last Post: 07-08-2011, 02:06 PM
  4. Article: Thickness gauging of Pipe
    By sumon emam in forum Home Articles
    Last Post: 07-03-2011, 08:39 PM
  5. Thickness limitation on X65 line pipe
    By liewnh in forum Pipeline And Fluid Flow
    Last Post: 03-25-2010, 02:43 PM
