Page 1 of 2 1 2 LastLast
Results 1 to 12 of 17
Thread: Pipe Thickness Calculation
    Hope you can use this spreadsheet
    Salam,
    jonas
    Attached Files Attached Files
  3. Hi Jonas,
    Can you Please explain me the Gas Pipe Line Sizing Calculation Please it is very urgent for me please help me with reference doc please ..........
  5. Hi Jonas,
    Hi sri,
    You could see at Pipeline Rule of thumb handbook page 325.
    the title is Calculate the velocity of gas in a pipeline.
    Good luck!
    Hi Jonas,
    Just wanted to point out a few errors in your spreadsheet. The Tabs titled ANSI B31.3, ANSI B31.4 & ANSI B31.8 should read ASME B31.3,ASME B31.4 and ASME B31.8 respectively as there are no such standards as ANSI B31.3, ANSI B31.4 and ANSI B31.8.
    thanks for excel file
    Muhammad Khurram
    Thank for your correction, there is no such standard like ANSI B31.3 and etc. The correct one is what DBS123 wrote(ASME B31.3 and etc)
    it's my bad, I forgot to change this tabs title. Thanks once again to DBS123.
    If there are any question for this calculation that I've made, please do not hesitate to discuss about it.
    Salam 'alaikum,
    jonas
  11. Hi Jonas,
    Please Share me Pipeline Rule of thumb handbook please .........
  12. Hi Jonas,
    Please Help me Below Gas Pipe Internal Diameter Calculation
    1.Argon Gas
    Flow = .90 cum/hr
    Pressure = 5.10bar
    Required Pipe I.D = ?
    2. Oxygen
    Flow = 4.90 cum/hr
    Pressure = 7 bar
    3.Propane
    Flow = .30 cum/hr
    Pressure = 7 bar
    Please help me please............
    If i use the spread sheet it would be 4" pipe for Argon Gas, 10" Pipe for Oxygen and 4" pipe for Propane.
  14. Jonas,
    Thank you for your reply but can u post me the calculation spread sheet for above requirement and Please Share me Pipeline Rule of thumb handbook please .........
  16. #12
    i think it's obviously clear, you just need to convert the unit and then put it in to spreadsheet.
    And for handbook, you can find and download it here.
  1. DNV standard for thickness calculation
    By hajit in forum Oil And Gas Process
    Last Post: 01-18-2019, 01:43 AM
  2. Calculation of structural minimum thickness of pipe
    By sumon emam in forum Pipeline And Fluid Flow
    Last Post: 11-28-2016, 11:04 PM
  3. Replies: 2
    Last Post: 06-20-2013, 11:13 AM
  4. calculation of insulation thickness
    By raji@singapura in forum Mechanical Engineering
    Last Post: 06-07-2010, 03:51 AM
