Thread: Article: Pipe Analysis Calculation Problem - Pipe Schedule
  1. Article: Pipe Analysis Calculation Problem - Pipe Schedule
    You can view the page at
  3. Re: Article: Pipe Analysis Calculation Problem - Pipe Schedule
    You will be needing ASME B31.4 or B31.8 instead B31.3 (it seems you are dealing with a pipeline)... you will also need design Pressure and Temperature in order to calculate minimum wall thickness (Mechanical Design).
    The hydraulic data you have will allow you to determine the optimum hydraulic diameter (considering flow speed and friction losses) and ASME's piping Codes (Serie B31) does not cover that issue... only mechanical design.
  5. nicely put.
  1. Pipe Analysis Calculation Problem - Pipe Schedule
    By mpougnet in forum Mechanical Engineering
    Last Post: 01-31-2013, 04:53 AM
  2. Article: (ask) analysis using caesar 5.1 ? for HDPE pipe ?
    By baronwisanggeni in forum Home Articles
    Last Post: 04-18-2011, 07:36 PM
  3. Article: Piping systems -Pipe Stress Analysis
    By Freeman in forum Home Articles
    Last Post: 07-15-2010, 09:43 PM
  4. Article: Pipe stress Analysis
    By cobraaa in forum Home Articles
    Last Post: 06-26-2010, 04:46 PM
  5. Pipe grade & pipe Schedule
    By WAT in forum Pipeline And Fluid Flow
    Last Post: 05-11-2009, 06:02 AM
