Results 1 to 5 of 5
Thread: High pressure steam to reduce into low pressure steam system
  1. Smile High pressure steam to reduce into low pressure steam system
    Hello Brothers and friends,
    i need urgently a economical and technical solution for reducing high pressure steam line into low pressure steam..
    Thank you very much, i appreciate very much
  3. Your question is open ended you must be more specific to expect some answer
    for example how much steam , at which conditions, is within a Plant , there are need to use steam in the intallation, is permanent solution, or just temporary and so on
    the most simple way for certain cases is a series of pressure reducing station consisting of several bypasses with control valves
  5. What you are looking for is measurement regulation station, which is consisted (normally) of:
    - filters
    - pressure regulators
    - saftey valves
    - turbine (normally) meters
    ...along with all of that come a number of ball or buterflly valves, pipes etc.
    Not trying to brag , but this is my latest constructed station (gas):
  6. Oh....just noticed you were looking for steam regulation....I was talking about gas, but I dont think there are to many differences
  7. Just use a PRV with a safety valve.
  1. Replies: 9
    Last Post: 09-29-2015, 10:25 AM
  2. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Planning & Project Management
    Last Post: 01-31-2011, 03:44 AM
  3. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Pipeline And Fluid Flow
    Last Post: 04-27-2010, 05:02 PM
  4. High pressure steam to reduce into low pressure steam system
    By achi81 in forum General Engineering
    Last Post: 04-24-2010, 05:48 AM
