Hello Brothers and friends,
i need urgently a economical solution for reducing high pressure steam line into low pressure steam..
Thank you very much, i appreciate very much
Depending on the amount and pressures of the steam ether a turbine or simple reduction valve..
Thanks for you reply henj...
The pressure of the steam is around 34 bar, and should be reduced into ~8 bar
Okay - roughly let us then say you get 50 kW electricity per ton steam/h you can calculate your earning and ask a supplier of steam turbines. My guess could be that you shall above 15-20 tons steam/h most of the year to get a good pay back. (not knowing your energy prices). Else chose the reduction valve
Well you may try my small program for turbines yourself:
Preferable if the steam is superheated to say 315 C it would gives ~62 kW/ton/h. Make sure the outlet is superheated T2_SH is a few degrees.
Hi HENJ ,
MESSAGE APPEAR AT IFILE.IT ....................... file expired
PLS RE UPLOAD
hello everyone =) i'm currently doing my exergy analysis on a power plant for my final year project. i was given a HBD n i did some calculation on d exergy . but it seems like i'm stucked ...need help urgently..plz3...tq
learnt something new...thanks
Thanks for the link.
