Thread: High pressure steam to reduce into low pressure steam system
  1. Smile High pressure steam to reduce into low pressure steam system
    Hello Brothers and friends,
    i need urgently a economical and technical solution for reducing high pressure steam line into low pressure steam..
    Thank you very much, i appreciate very much
    Oct 2008
    UAE Abu Dhabi
    Blog Entries
    1
    dear achi81
    you can do this in two scenarios:
    1- use regular chock valve with de-superheater (spray attemprator) to control the steam temperature, this option is cheap and simple.
    2- use turbo-expander, then you will not need attemprator and this option will be expensive and only needed when you ned to utilize the power from steam to re-compress another process stream.
    best regards
  5. Thank you very much !!!
  1. Replies: 9
    Last Post: 09-29-2015, 10:25 AM
  2. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Planning & Project Management
    Last Post: 01-31-2011, 03:44 AM
  3. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Pipeline And Fluid Flow
    Last Post: 04-27-2010, 05:02 PM
  4. High pressure steam to reduce into low pressure steam system
    By achi81 in forum General Engineering
    Last Post: 04-24-2010, 05:48 AM
