Hi all
can we determine productivity index from DST data in its flow periods?
if so,is the value obtained remains constant as long the Pwf(bottom hole flowing pressure) is higher than bubble point press?
knowing that i have applied eqn J=Q/(Ps-Pwf) on DST data, it gave J=5.2
but two months later memory gauges were run in hole to measure (bottom hole flowing pressure)
& i calculated J from its data & it gave a value of J=1.5
i got confused ....why did it change??which is correct??who am i??
AnY IdEas???![]()
