I love Crude columns...very first you have to check the heat balance in the unit...there are two ways of optimizing CDU...1st you fix the column specifications & use the heat available for the pump arounds ( This method is traditional...2nd you fix the heat requirement for the preheat trains & back calculate the heat flow in column (it is more rigorous & contemporary approach for column design). If you using the HYSYS simulator for this then keep in mind to split the feed in vapor & liqiud by checking the box available in HYSYS simulation. Also, the feed temperature to column & so exit temperature of fired heater should not exceed 690 deg F to avoid -----ing. Use double stage condeser configuration on column overhead as it gives more recovery of distillates. Keep in mind flashing of crude is at correct temp & pressure is most important in CDU..otherwise you have to rearrange the values of overflash.. I would recommend you to go through R. Watkins articles to know CDU optimization...also I have uploaded refinery material...follow this link...
Please let me know once you optimized the scheme..its really exciting....
