Page 5 of 9 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 49 to 60 of 107
Thread: a-S-P-E-N-O-N-E V 7.1 (2-0-0-9) INSTALLATION COMPLETE GUIDE .XP 3,VISTA,WINDOWS 7
  1. Quote Originally Posted by lammer View Post
    Very thanks Guga23!
    But I'd like to know all the steps (inclusive the inicial steps), because i still not get sucess !! I'd like to check if i am doing right the procedures.
    I really dont know the steps, because is very simple.
    If you havent installed the software, this is the full walk:
    1. Run the license generator and wait till its done.
    2. Run the dvd/image/setup,whatever you are using.
    3. When you click on install it will ask you to configure de licence so browse for the license file that you made early.
    4. Wait till it finish (can take from a couple of second to 30 minutes in some machines), if it doesnt say 710 licenses, go back and execute the license generator again and then use this new license to install. (check that it loads 710 licences).
    5. Now just click on all the Next buttons that you see, when it ask for type of license or installation (standalone license, server, both) I allways choose standalone.
    6. Click on all the yes/next/accept/whatever select the programs that you want to install and again click on all the yes/next/accept/whatever.
    If you already have installed the software but you get that no license found msg do the following.
    run the dvd/setup, and install any of the softwares that you didnt installed (unless you installed all) by using the new license.
    or
    1. Run the licence generator, copy that licence to the desktop so you can find it fast.
    2. Go to the windows start menu. Aspentech\commonutilities\SLM license profiler and execute that, select the license file that you copied to the desktop or where ever you put it.
    3. Click on Load Information and wait (can take a while). when it finish click on view licenseIf it says 710 you are ready to go. Close it. (install any aspentech software with this license or as I sayd above or
    4. Go to the windows start menu. Aspentech\commonutilities\SLM configuration wizard and execute.
    4a. on the first screen leave it as No and click on Next.
    4b. on the second screen click on yes and then on Next
    4c. on local file name select your license file, click down on type and select *.lic or *.* in case that the file doesnt show up. Leave the other option as they are. Click next.
    4d. Click next again
    4e. Click next again
    4f. Select "Register and optimize license type usage registry settings". Click to all the next and finish that will show up.
    At some moment it will say that the wizard will move the license that you selected to a specific folder that the software use to storage that. click on OK or Next or whatever it says.
    If by some way this doesnt work even when you have a license with 710 licenses. go back to 4f but dont select that option, just click on next. Since I have used the configuration wizard only once, I always use the setup to load the file.
    I have installed this software (v2006.5-v7-v7.1) on XP, vista basis/premium and win7 without any problem (except for the license file that I allways fix).
    Hope it works. Regards
    I have window 7 32 bit version. I have installed ASPEN v 7. However, it did not work as linceses are missing. further more above mentioned all links are dead. Pl help.
    Hello! Kottivec, just saw dis thread and really need help. Plz re-upload the file for help's sake. Thx
  6. #52
    I have installed on Window 7 32 bit as per advise and running well. Well done.
  7. #53
    After tons of failed installations, I've finally got this suit working on my Win7 32bit computer. Please try my simple way: Right click on ASPEN_LicGen.exe (****** file) and choose Run as Administrator. Then you use generated .lic file to install the software as usual.
    Hope it help.
  9. can any one tell me the procedure for installing aspen 7.1 on WinXP and also the ---- file. All of the above mentioned links are dead
  10. Good day
  11. the links do not work for me
  12. Need AspenOne 7.1 DVD2
  13. #58
    hi
    can you please uplad again
  14. pieeeeeeeeeeeeeeeeeeeeease upload this license agaiiiiiiiiiiiiiiiiiiin
  16. thanks so much for the great info
  1. Caesar II 5.1 installation on Windows Vista/7
    By mamali in forum Pipeline And Fluid Flow
    Last Post: 04-02-2017, 05:15 PM
