Tbe use of a five-point operator for the grid in Problem 2A (see
Appendix A) results in severe grid-orientation effects. The model
unrealistically predicts steam breakthrough at the far well (one eighth
producer) first. A small capillary Pressure was included to
introduce the minimum amount of dispersion that would damp out
incipient numerical fingers. Straight-line capilltwy pressure curves
were used, and tbe endpoint (i.e., maximum) values were 7 psi
[48 !&a] for tie liquid/gin system and 5 psi W kPa] for the oil/water
system. These values are well within acceptable limits. Bwaus.e
the gridblock are so large (about 30 II [9 m]), this amount of capillary
pressure has little effect on front thickness. Rerunning Problem
1A with the capillary pressure present produced results little
different from the mn with no capillary pressure.
