Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 68
Thread: European standards for piping
  1. hi Polo,
    do you have the canadian standard for external and internal coating?
    I'm very appreciate if you would share it with me.
    Many Thanks....
    English version of en13480
    Can any one please upload the english version of EN13480 of piping.I tried to extract information from friench but it is difficult.So PLease upload.Thanks in advance.
  5. héllo polo;
    I need CODETI, CODRES and CODAP
    please, can you upload then.
  6. #16
    Hey i need CODAP urgently, I already have PD5500 and En 13480-3, but its all waste without CODAP for me. Please pass it on , if you have.
    Quote Originally Posted by polo44600 View Post
    thank you for the detail between ASME and NFEN 13480.
    If you want i have a lot of european norme :
    CODETI
    CODRES
    CODAP
    NUCLEAR
  7. #17
    i also need codap,thanks
  9. Hello all,
    voici une "petite" partie de ma doc :
    here, my documentations
    si vous ètes interressé je peux uploader sur Rapidshare en Aout
    if you want i can upload on Rapidshare in August
    API 1102 Crossings
    API 1104 Welding of Pipelines
    API 2000 - Venting Tanks -April 1998
    API 2534 Measurement - Turbine meter
    API 2C Off shore cranes
    API 520 PSV SIZING
    API 527 PSV Seat Tightness
    API 542 ELEC LOW VOLTAGE
    API 543 ELEC MEDIUM VOLTAGE
    API 544 5 to 15 kV Switchgear
    API 560 Fired Heaters
    API 598 Valve Inspection and Testing
    API 5L Line Pipe Specifications
    API 607 Firetest Soft Seat Quarter Turn Valves
    API 610 - Centrifugal Pumps
    API 611 General service - Steam Turbine
    API 616 - Gas Turbines -August 1998
    API 617 - Centrifugal compressors -April 1988
    API 618 - Reciprocating Compressors 1995
    API 620 Welded Storage Tanks
    API 650 Welded Steel Tanks
    API 653 Tank Inspection
    API 660 Shell and Tube Exchangers
    API 661 Air Cooled Exchangers
    API 674 - PD Pumps -May 1980
    API 675 - PD Pumps Controlled volume 1994
    API 676 - PD Pumps - Rotary -December 1994
    API 681 - Vacuum Pumps and Compressors 1996
    API 6D Spec for Pipeline valves
    API 6FA Firetest - Valves
    API 6FC Firetest - Valves with Automatic Backseats
    API 700 Checklist for Plant completion
    API 750 Management of Process hazards
    API 752 Hazards Plants and Buildings
    API Catalog
    API Publications
    API RP 1110 Hydrotesting
    API RP 1621 Liquid stock control
    API RP 500 Electrical Classifications
    API RP 505 Elec Class Zone 0-1-2
    API RP 520 PSV SIZING
    API RP 521 PSV quide for Pressure Systems
    API RP 540 Electrical installations
    API RP 551 Process Measurement Instrumentation
    API RP 552 Transmission Systems
    API RP 553 Refinery Control Valves
    API RP 554 Process Inst and control
    API RP 572 Inspection of pressure vessels
    API RP 576 Inspection of PSVs
    API RP 579 Fit for service
    ASME 1 Rules for construction of Power Boilers
    ASME 31.3 Process piping
    ASME 5 Pressure Vessel Code
    ASME 8 Rules for Construction of Vessels
    ASME 9 Qualification Standard for Welders
    ASME B16-11 2005.pdf
    ASME B16.01-Cast Iron Pipe and flanges-1989
    ASME B16.05- Pipe Flanges and Flanged Fittings1996
    ASME B16.09- Factory made wrought steel Fittings-1993
    ASME B16.10 Face to Face valve Dimensions
    ASME B16.11.pdf
    ASME B16.20 Metallic Gaskets-1993
    ASME B16.21- Nonmetallic Gaskets1992
    ASME B16.25- Buttwelding Ends-1997
    ASME B16.28- Wrought Steel-1994
    ASME B16.34- Valves-1996
    ASME B16.47 Large diameter steel flanges
    ASME B16.5.pdf
    ASME B31 Code Simplified Piping Systems & Pipeline Asme Code Simplified.pdf
    ASME B31.01 Power Piping
    ASME B31.03 Chemical Plant and Refinery Piping code
    ASME B31.04 Liquid Transportation Systems
    ASME B31.08 Pressure Piping
    ASME B31G Remaining strength of corroded Pipelines
    ASME B36-10M Welded and Seamless Wrought Steel Pipe
    ASME B36-19M Stainless Steel Pipe
    ASME B36.10M_2000.pdf
    ASME MFC 3M Measurement of fluid flow
    ASME Pipes and Fittings Standards.doc
    ASME VIII Div. 2 2007.pdf
    Asme Welding Codes.pdf
    ASME _B31.3-2004-Process Piping.pdf
    ASME _B31[1].3-2004-Process Piping.pdf
    DIN 22102
    DIN 22131
    DIN 2501 Brides.pdf
    DIN 2512 Brides.pdf
    DIN 2526 Brides.pdf
    DIN 2527 Brides.pdf
    DIN 2558 Brides.pdf
    DIN 2565 Brides.pdf
    DIN 2573 Brides.pdf
    DIN 2605-2 Coudes.pdf
    DIN 2615-1 T‚s.pdf
    DIN 2616-1 R‚ductions
    DIN 2616-2 R‚ductions
    DIN 2617 Caps.pdf
    DIN 2630 Brides.pdf
    DIN 2641 Brides.pdf
    DIN 2652 Brides.pdf
    DIN 2673 Brides.pdf
    DIN 28115 Brides.pdf
    DIN 86029_30 Brides.p
    DIN 86044 Bride plate
    din _piping.pdf
    NF 001 Accessoires tuyauterie
    NF 002 Acier
    NF 003 Aluminium
    NF 004 Assemblage Soud‚s - Soudage
    NF 005 Batiments
    NF 006 Boulonnerie
    NF 007 Essais et Controles
    NF 008 Hydraulique
    NF 009 Pont roulant
    NF 010 Protection contre la Foudre
    NF NF A 49-716 Constitution externeriques verticaux
    NF 012 Robinetterie
    NF 013 Transporteurs … courroies
    NF 014 Tube
    NF AFNOR.pdf
    NF list
    NF NF 12241 1998.pdf
    NF NF A 49-716 Constitution externedu revetement du tube.pdf
    NF NF A 49-716 Constitution externe.pdf
    NF NF A 49-716 Constitution externefication des nuances d'acier.pdf
    NF NF A 49-716 Constitution externeaud en aciers de constructions
    NF NF A 49-716 Constitution externer pour appareil … pression
    NF NF A 49-716 Constitution externeier pour appareils sous pression
    NF NF A 49-716 Constitution externeves Pr‚vention de l'explosion et protection contre l'explosion Partie 1 Notions fondamentales et m‚thodologie.pdf
    NF NF A 49-716 Constitution externe‚gulation de gaz.pdf
    NF NF A 49-716 Constitution externe).pdf
    NF NF A 49-716 Constitution externee interne des structures m‚talliques.pdf
    NF NF A 49-716 Constitution externes … souder en bout pour appareil de robinetterie Butt Welding.pdf
    NF NF A 49-716 Constitution externeon des PN.pdf
    NF NF A 49-716 Constitution externeelles m‚talliques (DESP 97-23 CE)
    NF NF A 49-716 Constitution externedes produits et ‚l‚ments de construction Partie 1 Classement … partir des donn‚es d'essais de r‚action au feu.pdf
    NF NF A 49-716 Constitution externets pour les brides d‚sign‚es PN
    NF NF A 49-716 Constitution externeements relatifs au gaz naturel liqu‚fi‚-Interface terre navire (1997).pdf
    NF NF A 49-716 Constitution externes assemblages … brides circulaires avec joint.pdf
    NF NF A 49-716 Constitution externetemp‚rature.pdf
    NF NF A 49-716 Constitution externeation et pompes … chaleur - Exigences de s‚curit‚ et d'environnement - ‚dition 2000
    NF NF A 49-716 Constitution externees industriels Partie 2.pdf
    NF NF A 49-716 Constitution externeion Terminologie et symboels.pdf
    NF NF A 49-716 Constitution externeachines Notions fondamentales Principes g‚n‚raux de conception.pdf
    NF NF A 49-716 Constitution externetrole et du gaz naturel Contr“le & att‚nuation des feux et des explosions dans les installations en mer.pdf
    NF NF A 49-716 Constitution externeice en ‚l‚ments pr‚fabriqu‚s
    NF NF A 49-716 Constitution externeux ).pdf
    NF NF A 49-716 Constitution externeconstructions Charges d'exploitation des bƒtiments.pdf
    NF NF A 49-716 Constitution externeap‚s physiques (Juillet 1978).pdf
    NF NF A 49-716 Constitution externentier BTP … ‚chelles … marches ou escaliers Mai 2002.pdf
    NF NF A 49-716 Constitution externer destin‚s … l'accŠs et … l'‚vacuation du personnel.pdf
    NF NF A 49-716 Constitution externeon tuyauteries
    NF NF A 49-716 Constitution externetion du dialogue Homme-Ordinateur.pdf
    NF NF A 49-716 Constitution externeappareils … pression.pdf
    NF NF A 49-716 Constitution externee M‚nard.pdf
    NF NF A 49-716 Constitution externet essai - P‚n‚nomŠtre Type A.pdf
    NF NF A 49-716 Constitution externee des caoutchouc.pdf
    ABS 2003 Navires en Acier
    Affaires Maritimes
    BUREAU VERITAS 2005
    BV 2000
    CM66
    CODAP (R‚v 09-07, Edition 2005)
    CODETI
    CODRES Code Francais de Construction de reservoir cylindrique verticaux en acier
    Construction Navale Calcul r‚glementaire
    DNV
    Dossiers DESP PED - Directive europ‚enne 97-23-CE
    DTU20 travaux de bƒtiment ouvrages en ma‡onneriedepetits ‚l‚ments
    DTU21 travaux de bƒtiments ex‚cution des travauxenb‚ton
    equipements marin.xls
    EUROCODE Base de calcul des structures
    Glosssaire CODAP, CLAP, AQUAP, CCAP.doc
    IT89
    LLoyd's
    Machines
    Militaires
    Neige et vent
    Nucl‚aire RCCM 2000+2002 en anglais
    RŠglement PANAMA
    R‚cipients sous pression
    r‚glementation R‚seau Eau Pulv‚ris‚e.xls
    Solas
    Logiciel avec c*r*a*c*k:
    Software with c*r*a*c*k:
    Calul Bentley.AutoPipe.XM.v09.00.00.08
    Calul COADE CAESAR 5.1
    Calul Convert
    Calul evolution
    Calul Flowmaster
    Calul PDC
    Calul Pipe.Pack.V10.SP3
    Calul PipeFlow1037
    Calul pipe_flow_2009
    Calul Pipe_Flow_Expert_v1.08_Incl_******-DIGERATI
    Calul Portable_Engineering_Power_Tools_-_Plus_Edition_v2.0.4
    Calul rdm6
    Calul Robobat 19, 20 & 21
    Calul SF PRESSURE DROP 6.2
    CAO DAO 3D MODELS
    CAO DAO Acad LT 2009
    CAO DAO Alias_I-Run_v3.4.5
    CAO DAO AutoCad 2008 32bits
    CAO DAO AutoCad 2010 32bits
    CAO DAO Autodesk Inventor 11
    CAO DAO Autoplant_2004
    CAO DAO Bentley Microstation V8
    CAO DAO CadFix71
    CAO DAO CadPipe
    CAO DAO Catia.P3.V5R17
    CAO DAO Coade Cadworx 2008
    CAO DAO Coade Cadworx Pack 2008
    CAO DAO Coade Cadworx PRO Pack 2009
    CAO DAO Intergraph Plant Design system 8.0
    CAO DAO NavisWorks Jetstream
    CAO DAO PDMS 11.6
    CAO DAO PDMS 12
    CAO DAO plate_n_sheet_4.05
    CAO DAO ProSteeelV18
    CAO DAO Rhinoc‚ros
    CAO DAO SolidWorks 2007
    Thank's at all for this very good forum
    Polo44600
    A French Piping designer
  10. Quote Originally Posted by polo44600 View Post
    Hello all,
    CAO DAO PDMS 12
    Polo44600
    I am very interested by PDMS 12 with -----!
    Give link, please.
  11. #20
    Oct 2008
    The Netherlands
    Blog Entries
    14
    To Polo 44600
    Salut
    I am looking for Codres Division 2
    ( Recommandations pour la maintenance des reservoirs Cylindriques verticaux )
    This was published in 2009.
    This standard is a complementary one to the old Codres.
    This standard is equivalent to the american API 653 ( I have this one )
  12. #21
    Upload soon pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
    waiting 4 ur collections
    thank uuuuuuuuuuuuuuuuuuuuu
  13. Dear polo
    You are having a fantastic collection. Can u pl. tell me whether all the files are in english or in other languages. If you have english version, all right otherwise those files are to be translated into english.
    Whatever it is, pl. upload all.
    Thanks & Regards
    jgp123
    Hello all,
    API 1102 Crossings
    API 520 PSV SIZING
    API Catalog
    API Publications
    ASME B16.11.pdf
    ASME B16.5.pdf
    DIN 22102
    DIN 22131
    DIN 2501 Brides.pdf
    DIN 2512 Brides.pdf
    DIN 2526 Brides.pdf
    DIN 2527 Brides.pdf
    DIN 2558 Brides.pdf
    DIN 2565 Brides.pdf
    DIN 2573 Brides.pdf
    DIN 2615-1 T‚s.pdf
    DIN 2617 Caps.pdf
    DIN 2630 Brides.pdf
    DIN 2641 Brides.pdf
    DIN 2652 Brides.pdf
    DIN 2673 Brides.pdf
    din _piping.pdf
    NF 002 Acier
    NF 003 Aluminium
    NF 005 Batiments
    NF 006 Boulonnerie
    NF 008 Hydraulique
    NF 009 Pont roulant
    NF 012 Robinetterie
    NF 014 Tube
    NF AFNOR.pdf
    NF list
    Affaires Maritimes
    BUREAU VERITAS 2005
    BV 2000
    CM66
    CODETI
    DNV
    IT89
    LLoyd's
    Machines
    Militaires
    Neige et vent
    RŠglement PANAMA
    Solas
    Calul Convert
    Calul evolution
    Calul Flowmaster
    Calul PDC
    Calul PipeFlow1037
    Calul rdm6
    CAO DAO 3D MODELS
    CAO DAO CadFix71
    CAO DAO CadPipe
    CAO DAO PDMS 11.6
    CAO DAO PDMS 12
    CAO DAO Rhinoc‚ros
    Polo44600
  14. I also need EN 13480 english version. Pls upload
  16. #24
    many thnx
  1. European standards for piping & instrumentation
    By eddiem in forum Petroleum Refining
    Last Post: 05-23-2013, 09:09 AM
  2. European or DIN standards for Plastic Piping
    By alavi1364 in forum Pipeline And Fluid Flow
    Last Post: 03-05-2012, 11:12 AM
  3. European and american standards
    By codrincob in forum Mechanical Engineering
    Last Post: 02-27-2012, 05:29 PM
  4. European standards
    By evantefal in forum Mechanical Engineering
    Last Post: 01-29-2010, 06:54 AM
  5. European Pipe Dimension Standards
    By TMN in forum Pipeline And Fluid Flow
    Last Post: 10-07-2009, 05:48 PM
