Thread: European or DIN standards for Plastic Piping
  1. European or DIN standards for Plastic Piping
    Hi
    I would be so pleased if anyone help me know that for plastic piping especially Polyethylen type, which European or DIN standards or any other handbooks that refere to these standards can be used. I had found some handbooks, but they all refere to American standards such as ASME or ASTM.
    HI, HERE YOU COULD FIND ALL THE STANDARDS FOR THE GRP PIPES.
    BSi Standards
    Fiberglass related standards from BSi - British Standards institute
    • BS 5480 - Specification for glass reinforced plastics (GRP) pipes, joints and fittings for use for water supply or sewerage
    • BS 6464 - Specification for reinforced plastics pipes, fittings and joints for process plants
    • BS 7159 - Code of practice for design and construction of glass-reinforced plastics (GRP) piping systems for individual plants or sites
    • BS 8010-2.5 - Code of practice for pipelines - Pipelines on land: design, construction and installation - Glass reinforced thermosetting plastics
    DIN Standards
    Fiberglass related standards from DIN - Deutsches Institut für Normung
    • DIN 53393 - Testing of Textile Glass-reinforced Plastics; Behavior to the Effect of Chemicals
    • DIN 53758 - Testing of plastics articles; determination of the effect of internal pressure on hollow objects by short-time test
    • DIN 53768 - Determination by extrapolation of the long-term behavior of glass fiber reinforced plastics
    • DIN 53769-1 - Testing of glass fiber reinforced plastics pipes; determination of the longitudinal shear strength of type B pipe fittings
    • DIN 53769-2 - Testing of glass fiber reinforced plastics pipes; long-term hydrostatic pressure test
    • DIN 53769-3 - Testing of glass fiber reinforced plastics pipes; determination of initial and long-term ring stiffness
    • DIN 53769-6 - Testing of glass fiber reinforced plastics pipes; Testing of pipes and fittings under pulsating internal pressure
    • DIN EN 59 - Glass Reinforced Plastics; Measurement of Hardness by Means of a Barcol Impressor
    • DIN EN 637 - Plastics piping systems - Glass-reinforced plastics components - Determination of the amounts of constituents using the gravimetric method
    • DIN EN 705 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analyses and their use
    • DIN EN 761 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions
    • DIN EN 1393 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes; Determination of initial longitudinal tensile properties
    • DIN EN 1447 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of long-term resistance to internal pressure
    • DIN EN 1448 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) components - Test methods to prove the design of rigid locked socket- and -spigot joints with elastomeric seals
    • DIN EN 1449 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) components - Test methods to prove the design of a cemented socket- and -spigot joints
    • DIN EN 1450 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) components - Test methods to prove the design of bolted flange joints
    ISO Standards
    Fiberglass related standards from ISO - International Organization for Standardization
    • ISO 178 - Plastics - Determination of flexural properties
    • ISO 527-4 - Plastics - Determination of tensile properties - Part 4: Test conditions for isotropic and orthotropic fibre-reinforced plastic composites
    • ISO 7370 - Glass fiber reinforced thermosetting plastics (GRP) pipes and fittings; Nominal diameters, specified diameters and standard lengths
    • ISO 7510 - Plastics piping systems - Glass-reinforced plastics (GRP) components - Determination of the amounts of constituents using the gravimetric method
    • ISO 7684 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions
    • ISO 10466 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Test method to prove the resistance to initial ring deflection
    • ISO 10928 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use
    • ISO/TR 10465-1 - Underground installation of flexible glass-reinforced thermosetting resin (GRP) pipes; part 1: installation procedures
    • ISO/TR 10465-2 - Underground installation of flexible glass-reinforced thermosetting resin (GRP) pipes - Part 2: Comparison of static calculation methods
    • ISO/TR 10465-3 - Underground installation of flexible glass-reinforced thermosetting resin (GRP) pipes - Part 3: Installation parameters and application limits
  5. Re: European or DIN standards for Plastic Piping
    Hi, for PE pipes the german (DIN) standards are DIN 8074 and DIN 8075. For EN the general standards are EN 1519 (parts 1 to 3) and EN 12666-1 (underground drainage). There is also EN 12201, which is PE water pipes.
  1. European standards for piping
    By vvvv in forum Pipeline And Fluid Flow
    Last Post: 10-28-2015, 10:41 PM
  2. European standards for piping & instrumentation
    By eddiem in forum Petroleum Refining
    Last Post: 05-23-2013, 09:09 AM
  3. Plastic Piping Systems
    By jhonniewalk in forum Petroleum Refining
    Last Post: 09-23-2011, 12:42 AM
  4. Plastic Piping Handbook
    Last Post: 05-07-2010, 11:26 AM
  5. European standards
    By evantefal in forum Mechanical Engineering
    Last Post: 01-29-2010, 06:54 AM
