thanks for your kind to share to newbie like me :-)
M. Taufik
Junior Mechanical Engineer
M. Taufik
Thanks for your link mr. ccpjeff
But after downloaded this file, I can't open it. There is message like this "Run time error '13' type miss match".
So, what happened with this file. Will you give me advise for me?
Thank a million for your attention
M Taufik
Hi Mr.Abdel Halim,
It would be really helpful to me if you can share me the excel spreadsgeet for Flange Design calculations
First sorry for my English.
I have arranged the sheet excel sent, for it the steps to continuing are:
To eliminate the protection of the sheet :
- Sheet 1 password: [ZGEUPYDHKSQFTAX] (no brackets)
- VBA Project password: [556] (no brackets)
After eliminating the protection, it must be substituted "." For "," in the first book ( " Flange " ) ; of the above mentioned way the mistake will eliminate 13 existing in the leaf sheet and the leaf sheet was working correctly.
regards
Another solution would be the change of the regional configuration of the PC, replacing it ", "for "."
Thanks a lot for your advise. I appreciate your effort to help my problem. But I still found difficulty (because of my little knowledge) when input password "556" to open VBA project password, there is warning like this "the password is invalid".
I confuse what should I do..? will you share to me the fix spreadsheet?
I am sorry for your inconvenient. Thanks for your attention.
Moch. Taufik
Just for information,
The other way to design non standard flange, you can find in the below link :
Forge Taylor - Modern Flange Design "Bulletin 502" - 1 (53 Pages & 2.565 MB):[link Point to another website Only the registered members can access]
thank you
Hello fellow (bapug98) find check list, i have but in spanish, but all company most be have its
Hi, Moch. Taufik;
For Flange Rating_(NPS 0.5~24)_V3.0.xls :
VBA Project password: [21CD] (no brackets)
For Flange Rating_Large Diameter_(NPS 26~60)_V1.0.xls :
