Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 13 to 24 of 32
Thread: ASME Flange Design Calculations
  1. #13
    Smile
    thanks for your kind to share to newbie like me :-)
    Regards,
    M. Taufik
    Junior Mechanical Engineer
    Advertising world
    Thanks for your link mr. ccpjeff
    But after downloaded this file, I can't open it. There is message like this "Run time error '13' type miss match".
    So, what happened with this file. Will you give me advise for me?
    Thank a million for your attention
    Regards,
    M Taufik
  5. Hi Mr.Abdel Halim,
    It would be really helpful to me if you can share me the excel spreadsgeet for Flange Design calculations
  6. #16
    First sorry for my English.
    I have arranged the sheet excel sent, for it the steps to continuing are:
    To eliminate the protection of the sheet :
    - Sheet 1 password: [ZGEUPYDHKSQFTAX] (no brackets)
    - VBA Project password: [556] (no brackets)
    After eliminating the protection, it must be substituted "." For "," in the first book ( " Flange " ) ; of the above mentioned way the mistake will eliminate 13 existing in the leaf sheet and the leaf sheet was working correctly.
    regards
  7. #17
    Another solution would be the change of the regional configuration of the PC, replacing it ", "for "."
  9. #18
    Thanks a lot for your advise. I appreciate your effort to help my problem. But I still found difficulty (because of my little knowledge) when input password "556" to open VBA project password, there is warning like this "the password is invalid".
    I confuse what should I do..? will you share to me the fix spreadsheet?
    I am sorry for your inconvenient. Thanks for your attention.
    Regards,
    Moch. Taufik
  10. Just for information,
    The other way to design non standard flange, you can find in the below link :
  11. #20
    Forge Taylor - Modern Flange Design "Bulletin 502" - 1 (53 Pages & 2.565 MB):
  12. #21
    thank you
  13. #22
    Hello fellow (bapug98) find check list, i have but in spanish, but all company most be have its
  14. #23
    Aug 2009
    India
    Blog Entries
    11
    Quote Originally Posted by arunrajendran View Post
    Hi Mr.Abdel Halim,
    Hello spreadsheet Seekers !!!
    Have you tried this ?
  16. #24
    Quote Originally Posted by m.taufik View Post
    Regards,
    Moch. Taufik
    Hi, Moch. Taufik;
    For Flange Rating_(NPS 0.5~24)_V3.0.xls :
    VBA Project password: [21CD] (no brackets)
    For Flange Rating_Large Diameter_(NPS 26~60)_V1.0.xls :
  1. ASME Flange Design Calculations
    By Abdel Halim Galala in forum Engineering Spreadsheets & Presentations
    Last Post: 06-16-2018, 07:29 PM
  2. Shell and Tube Heat Exchanger Mechanical Design Calculations per ASME & TEMA
    By Abdel Halim Galala in forum Mechanical Engineering
    Last Post: 05-05-2017, 01:48 PM
  3. Pressure Vessel Design Calculations as per ASME BPVC - Section VIII, Division 1
    Last Post: 08-19-2015, 06:44 AM
  4. Replies: 2
    Last Post: 08-28-2013, 09:42 AM
  5. Query on Flange Design as per ASME Section VIII, Div.1, App 2
    By hssimha in forum Mechanical Engineering
    Last Post: 03-13-2012, 11:10 AM
