Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 32
Thread: ASME Flange Design Calculations
    The following link is very interesting to proceed an ASME design calculations for non-standard flanges:
    Also, the following link is used for design of ASME non-standard blind flanges: ..................................
    Note. The rating/class of standard flange can be easily found from ASME B16.5 or ASME B16.47 just by defining the flange material and knowing the design conditions (pressure & temperature), and just defining the class or rate of the flange, you can find all the dimensions from the related ASME codes (ASME B16.5 or ASME B16.47). And in this case, no need to proceed a flange design calculations as prescribed for non-standard flanges. See the following site to find the max. design pressure of a flange as per ASME B16.5: .................................................. .................................................. .............
    To recognize the definition of flange class or rating per ASME code, see the the following link: ............
    See More: ASME Flange Design Calculations
    Thank you Abdel Halim.
    My threads; Kamel :
    thanks so much ...
    My threads; dr4u :
    • #5
    •    Spons.
    • I imitate the calculation sheet from the website (
      Try it, and your any comments is welcome.
      Flange Rating_(NPS 0.5~24)_V3.0.xls Based on ASME B16.5 2009
      Flange Rating_Large Diameter_(NPS 26~60)_V1.0.xls Based on ASME B16.47 2006
    • #7
    • #8
      Lot of thankx to "Abdel Halim Galala" & "ccpjeff"
    • many thanks sir
      My threads; dragonpvgas :
    • well i m a mechanical engineer and involved in work static equipment designing-pressure vessel, heat xchanger, column, tower, i have to check the GA 7 fabrication drawings for these .can any body help me how to improve on this any reference book, document regarding these drawings, specific points to be considered while checking drawing
    • #11
      thanks for sharing...
      My threads; eriyanto.edy :
      •    Spons.
      • #12
        thanks for your kind to share to newbie like me :-)
        M. Taufik
        Junior Mechanical Engineer
        My threads; m.taufik :
        1. ASME Flange Design Calculations
          By Abdel Halim Galala in forum Engineering Spreadsheets & Presentations
          Last Post: 01-04-2018, 11:38 AM
        2. Shell and Tube Heat Exchanger Mechanical Design Calculations per ASME & TEMA
          Last Post: 05-05-2017, 01:48 PM
        3. Pressure Vessel Design Calculations as per ASME BPVC - Section VIII, Division 1
          Last Post: 08-19-2015, 06:44 AM
        4. Replies: 2
          Last Post: 08-28-2013, 09:42 AM
        5. Query on Flange Design as per ASME Section VIII, Div.1, App 2
          By hssimha in forum Mechanical Engineering
          Last Post: 03-13-2012, 11:10 AM
