Page 1 of 5 1 2 3 ... LastLast
Results 1 to 12 of 50
Thread: ASME Flange Design Calculations
    The following link is very interesting to proceed an ASME design calculations for non-standard flanges:
    Also, the following link is used for design of ASME non-standard blind flanges: ..................................
    Note. The rating/class of standard flange can be easily found from ASME B16.5 or ASME B16.47 just by defining the flange material and knowing the design conditions (pressure & temperature), and just defining the class or rate of the flange, you can find all the dimensions from the related ASME codes (ASME B16.5 or ASME B16.47). And in this case, no need to proceed a flange design calculations as prescribed for non-standard flanges. See the following site to find the max. design pressure of a flange as per ASME B16.5: .................................................. .................................................. .............
    To recognize the definition of flange class or rating per ASME code, see the the following link: ............
    Thank you Abdel Halim.
    thanks so much ...
  6. Hi Mr Galala
    Can you please share the spreadsheets of the above calculations ?
    Thanks in advance
    Praphulla.dp@gmail.com
    Praphulla
  9. I imitate the calculation sheet from the website (
    Try it, and your any comments is welcome.
    Flange Rating_(NPS 0.5~24)_V3.0.xls Based on ASME B16.5 2009
    Flange Rating_Large Diameter_(NPS 26~60)_V1.0.xls Based on ASME B16.47 2006
    thanks Abdel Halim Galala and ccpjeff
    Muhammad Khurram
    Lot of thankx to "Abdel Halim Galala" & "ccpjeff"
  12. many thanks sir
  13. well i m a mechanical engineer and involved in work static equipment designing-pressure vessel, heat xchanger, column, tower, i have to check the GA 7 fabrication drawings for these .can any body help me how to improve on this any reference book, document regarding these drawings, specific points to be considered while checking drawing
  14. #11
    thanks for sharing...
  16. #12
    thanks for your kind to share to newbie like me :-)
    M. Taufik
    Junior Mechanical Engineer
  1. Shell and Tube Heat Exchanger Mechanical Design Calculations per ASME & TEMA
    Last Post: 05-05-2017, 01:48 PM
  2. Pressure Vessel Design Calculations as per ASME BPVC - Section VIII, Division 1
    Last Post: 08-19-2015, 06:44 AM
  3. Replies: 2
    Last Post: 08-28-2013, 09:42 AM
  4. ASME Flange Design Calculations
    Last Post: 10-12-2012, 03:26 PM
  5. Query on Flange Design as per ASME Section VIII, Div.1, App 2
    By hssimha in forum Mechanical Engineering
    Last Post: 03-13-2012, 11:10 AM
