Page 14 of 29 FirstFirst ... 4 12 13 14 15 16 24 ... LastLast
Results 157 to 168 of 347
Thread: Eclipse step by step
  1. #157
    following
  3. Quote Originally Posted by temr View Post
    Use data from well tests fro position of you Owc
    what kind of well test Sir? cos i don't have RFT test
    Jan 2009
    ALA, KZ
    Hello acang_024,
    I talking of MDT data if you have or
    when you 1 time perforate the well you get type of inflow , use this to mark the possible water level
  6. Dear All
    I have a problem with coding Corner point geometry in Eclipse software. I have read manual of eclipse but I didn't understand all material . I know that with use of COORD and ZCORN in GRID section I can build my model, but I don't know how I must put data.
    i appreciate your help.
    Regards;
  7. #161
    Jan 2009
    ALA, KZ
    What kind of problem you have?
    Coord
    This keyword is used to specify coordinate lines in Z direction. A coordinate line defines
    the possible position for grid block corner points, for each (i,j) cell. A coordinate line is
    specified by two triplets of X, Y and Z coordinates, representing two distinct points on it.
    Zcorn
    Each grid block has 8 corners. This keyword enables the depths of each corner of each grid
    block to be separately specified. It is used for specifying depths for corner point geometry.
    The keyword line is followed by 2 NX  2 NY  2 NZ values, with the two corners
    in the X direction of the first grid block being specified first, then two corners for the next
    block in the i direction, and so on.
    In order to understand this make small gmodel in petrel or load the one i use in this tutorial
    and export model in eclipse style geometry data
    Then open this file in text format and load set of coord data as point and you will see the magic
  9. Eclipse ( corner point problem)
    Dear temr
    Thank you for your response.
    I have 5 block to model. Each block has its own size that differs from another block.and I have also amount of structure tops. how I must use these data, in the manual of Eclipse there is this example
    Example:
    Here NDIVIX = 3, NDIVIY = 2, NDIVIZ = 10, and NUMRES =1:
    (NDIVIX + 1)(NDIVIY + 1)NUMRES
    COORD
    0 0 1000 0 0 1000
    1000 0 1000 1000 0 1000
    2000 0 1000 2000 0 1000
    3000 0 1000 3000 0 1000
    0 2000 1000 0 2000 1000
    1000 2000 1000 1000 2000 1000
    2000 2000 1000 2000 2000 1000
    3000 2000 1000 3000 2000 1000
    0 4000 1000 0 4000 1000
    1000 4000 1000 1000 4000 1000
    2000 4000 1000 2000 4000 1000
    3000 4000 1000 3000 4000 1000
    I don't know how I must do this with my data. as I told I have 5 data of block size in the X direction,5 data of block size in the Y direction,5 data of block size in the Z direction and 5 data of Depth of the structure top ,
    I appreciate your help.
    Regards;
  10. #163
    Jan 2009
    ALA, KZ
    Use Petrel to build grid it is the easy way to understand
    1 way just import you grid to petrel for eclipse examples
    2 make grid by your self
    in your example this a not coordinates but increments from initial coordinates system
  11. I didn't use Petrel at all and I have not this software. is there another way to model?
    anyway, thank you for your help.
    Regards;
  12. I didn't use Petrel at all and I have not this software. is there another way to model?
    Regards;
  13. #166
    Jan 2009
    ALA, KZ
    Better if you will see what you creating.
    In eclipse it very hard to do this as all its interface is not interface at all
    Lookup petrel in the forums or ask for it
    If you will start using petrel now it will save you a lot of time in the future
  14. what the keyword i have to use, if i wanna shut in well when the THP reach/under 200 psi? i use e300, i used to use WCONPROD, but after THP reach/under 200 psi, the software change to BHP as control pressure
  16. #168
    Nov 2008
    Australia
    Can you paste your WCONPROD line here to check what your current control points and limits are set to?
  1. Replies: 11
  2. Eclipse Step by Step?
    By Zuper in forum Reservoir
    Last Post: 04-05-2012, 12:56 AM
  3. Step by step to calculate control valve Cv thorugh Intools
    By hswang2 in forum Instrumentation & Control
    Last Post: 11-28-2010, 09:37 AM
