Thread: Step by step to calculate control valve Cv thorugh Intools
    Dear expert
    Could anyone help to post any documment to do
    Thank you very much.
    Dear hswang2,
    Exactly I don't have any document but i've just tried to help you by mention it step by step suitable with my experienced :
    1. Open calculation module
    2. Select calculation type that you need it (for this topic is control valve)
    3. Enter tag number
    4. Click highlight to show fields which need to be filled (Service, Fluid State, Line Number, Line Size)
    5. Enter data from process which need to be filled as calculation data
    6. Click calculate after finish
    7. If Control Valve Calculation window showed then you have to adjust the coloumn filled (Calculation Method, Flow Coeficient, Noise calculation method, etc) based on your requirement
    8. Click calculate after finish then intools will show you the results from Cv value, Regime & Noise Condition for @minimum, @normal & @maximum load condition
    I think the steps above are enought for you and for more information please open Help module, there are more advice for you need it, Good Luck friend...
    ady_edan
  1. Replies: 11
  2. How to calculate the Step out depth in drilling
    By africaproject in forum Oil And Gas Production
    Last Post: 12-16-2009, 04:38 AM
