Quote Originally Posted by inconel View Post
Hi everybody,
I am looking for weld metal(weight) calculation for pipe welding.anybody having any excel work sheet or worked out method ,please share it over here or send to my e-mail address mentioned below.I have to order electrodes for production welding. Following is the dimensions of the joint .Thickness of pipe 18 mm, 70 Degree angle single V-Groove,1 mm root face,1.5 mm root opening. I have calculated total volume of joint all around pipe.then divided it by density of weld metal(mild steel) to get mass of the weld metal required to fill the groove. But the result is not correct due to some unit conversion mistake.I am looking for help from all the members over here interested in this subject.I am new in welding engineering and don't have much idea about this .Expecting help from my seniors and friends.
My e-mail sunilkmani@gmail.com
Thank you in advance
Sunil K. Mani
I also need it too,... how to calculate time of welding? consumeable flux? for spiral weld and or long seam weld or circum weld?...
please give me the formulas or ebook for basic welding calculation.
thanks ....
Taqobalallohu minna waminkum
Happy Id'l Fitri
