im confused in input of
Net thickness of reservoir
i have net perforated interval and gross
can i put net perforated interval in the place of net thickness of reservoir
at the first step of ecrin sapire well test software
Best Regards
Zaheer Ahmed
Reservoir Engineer
Islamabad, Pakistan
Dear friend
my advice is to use the effective length, which mean the length of the perforation which is active (contributing). You have to take a look at PLT
survey if it is available. Be careful the h value will have an enormous effect on your permeability.
perforation should be considered as geometrical skin if not perforated across the full reservoir height!
