Results 1 to 12 of 12
Thread: Variogram Analysis
    Variogram Analysis
    Hello All,
    Could any one please help me to get more information and/or books related to variogram and geostatistics analysis also i need to know if there is any software to make the variogram analysis
    thank you very much
    best regards
  3. I have it.. trhee, but i will exchange for any software of blasting.
    hello sadat666
    which software you mean ??
  6. Hello Sami22
    If you want compute 2D variogran you can use variowin if 3D yo can use gslib both are free software. The very good book for undertand variogram is Introduction to applied geoestatistics by M. Srivastava. Other sofwares Wingslib, GOCAD and Petrel.
    good luck
    Thank you very much Viloriarj for this information, can you please tell me what is the difference between 2D and 3D variogram
  9. Hi Sami22
    Depent of your data. For exemple if you have thikness, netsand, top, botton, average of porosity, or permeability of the resevoir the variogram have to compute in 2D, the data is X,Y and the value of properties (thikness, netsand, others). Now if you have porosity, permeability in a geological unit you have compute the 3D variogram. You data have X, Y at the location well, Z each 1 meter or feet
  10. Dear Collegues,
    I'm trying to build variogram model for existing lithoface grid using gam program from GSLIB distribution. I define indicator semivariogram as variogram output type:
    Code:
                      Parameters for GAM
    START OF PARAMETERS:
    18_face-region.txt    -file with data
    1   1                 -   number of variables, column numbers
    -100 100              -   trimming limits
    gam.out               -file for variogram output
    1                     -grid or realization number
    100  50    100.0      -nx, xmn, xsiz
    200  50    100.0      -ny, ymn, ysiz
     1   0.25  0.5        -nz, zmn, zsiz
    2  50                 -number of directions, number of lags
     1  0  0              -ixd(1),iyd(1),izd(1)
     0  1  0              -ixd(2),iyd(2),izd(2)
    1                     -standardize sill? (0=no, 1=yes)
    1                     -number of variograms
    1   1   10  2.5       -tail variable, head variable, variogram type
    type 1 = traditional semivariogram
         2 = traditional cross semivariogram
         3 = covariance
         4 = correlogram
         5 = general relative semivariogram
         6 = pairwise relative semivariogram
         7 = semivariogram of logarithms
         8 = semimadogram
         9 = indicator semivariogram - continuous
         10= indicator semivariogram - categorical
    When I run the program I've got zeroed columns in output
    Code:
    Indicator 1/2 Variogram tail:Indicator  1 head:Indicator  1  direction  1
       1      100.000      0.00000    19800        0.00000        0.00000
       2      200.000      0.00000    19600        0.00000        0.00000
       3      300.000      0.00000    19400        0.00000        0.00000
       4      400.000      0.00000    19200        0.00000        0.00000
       5      500.000      0.00000    19000        0.00000        0.00000
       6      600.000      0.00000    18800        0.00000        0.00000
       7      700.000      0.00000    18600        0.00000        0.00000
       8      800.000      0.00000    18400        0.00000        0.00000
       9      900.000      0.00000    18200        0.00000        0.00000
      10     1000.000      0.00000    18000        0.00000        0.00000
      11     1100.000      0.00000    17800        0.00000        0.00000
      12     1200.000      0.00000    17600        0.00000        0.00000
    Can you tell me what's wrong?
    ... ah, I see I give the wrong number for cutoff parameter in variogram type definition.
    Jan 2009
    ALA, KZ
    take this
    but for me the range of variogramm is the range of your geobodies normally i take double distance between the wells
    Jan 2009
    ALA, KZ
    Quote Originally Posted by Sadat666 View Post
    Shame on you !!!!
    Quote Originally Posted by temr View Post
    Shame on you !!!!
    Thanks term
  14. hello...
    can anybody share this book?
    "Applied Geostatistics with SGeMS" by Nicholas Remy
    Thanks..
  16. Re: Variogram Analysis
    Hi temr, the link does not work. Would you like upload again. I needed to learn it. I need some books to learn about geostatistics. Thank you for help
  1. PTA analysis
    By pet_engi in forum Reservoir
    Last Post: 04-08-2014, 12:13 PM
  2. AVO Analysis
    By seismic.world in forum Geology & Exploration
    Last Post: 02-11-2014, 01:57 AM
  3. RAM Analysis
    By anwarahmad in forum Mechanical Engineering
    Last Post: 04-05-2013, 10:57 PM
  4. Bow-Tie Analysis Example
    By cnytsan in forum Safety And Environment
    Last Post: 09-27-2011, 08:08 PM
