Results 1 to 7 of 7
Thread: PTA analysis
    PTA analysis
    Dear RE`s
    Nowadays I am working on PTA analysis (build up test),I try to build an excel sheet fit with this purpose .
    but unfortunately I have problem with pressure derivative calculation.
    it will be my pleasure If any one has a such excel sheet or an advice .
    Re: PTA analysis
    Der pet_engi,
    In the past I built an spreadsheet for such purposes, unfortunatelly I can't share it since it's now property of the last company I worked for. However, pressure derivatives can be easily calculated using Forward, Central or Backward numerical differentiation. Since the error of the Central difference approximation is less than that of the other two methods, this is the preferred approximation.
    Re: PTA analysis
    Check here.
    Quote Originally Posted by pet_engi View Post
    Dear RE`s
    Re: PTA analysis
    Check here.
    Dear RE`s
    Re: PTA analysis
    Dears
    Thanks a lot for your valuable advice.
    Re: PTA analysis
    Dear DAH7542
    Firs of all I would to say many thanks for your quick response
    I need this spread sheet for personal using ,not for a public use ,
    so that if you can share a part of your spread sheet ,it will be my pleasure
    Warm Regards
  10. Re: PTA analysis
    Thank you!
  1. DST analysis
    By arm in forum Reservoir
    Last Post: 04-14-2014, 09:27 AM
  2. AVO Analysis
    By seismic.world in forum Geology & Exploration
    Last Post: 02-11-2014, 01:57 AM
  3. PVT analysis
    By swpuxiaofan in forum Reservoir
    Last Post: 10-08-2013, 12:56 PM
  4. PVT-Analysis
    By petengr in forum Reservoir
    Last Post: 10-12-2011, 11:50 PM
  5. Bow-Tie Analysis Example
    By cnytsan in forum Safety And Environment
    Last Post: 09-27-2011, 08:08 PM
