Results 1 to 9 of 9
Thread: OWC and FWL
  1. OWC and FWL
    Hi everyone,
    Something that I can't understand really is how it can be that for oil wet reservoir the FWL is above the OWC
    can someone explain it?
    Re: OWC and FWL
    In a capillary tube, water-wetting surface forces cause water to rise (thus OWC above FWL) displacing oil, but if the tube inner surface is oil-wetting, the oil will push water down (thus OWC below FWL).
    Read this: "Fundamentals of Wettability " by Schlumberger. Download from:
    Re: OWC and FWL
  6. Re: OWC and FWL
    thanks DAH but this in a capillary tube, how it can happen really in a reservoir
    Re: OWC and FWL
    Pore throat network in porous rocks are physically describe as capillary tubes. The physics are the same. Take a look at the paper "Fundamentals of Wettability " by Schlumberger and you'll get an idea of these physical principles.
    Jan 2009
    ALA, KZ
    Re: OWC and FWL
    To speak shortly
    FWL- is the level from you model you PC curve
    OWC - is the level where you get pure water and can cave some oil there but in in movable condition
    The diff is FWL is almost cases is lower than OWC
    but there reservoirs where FWL is higher than OWC
    Jan 2009
    ALA, KZ
    Re: OWC and FWL
    To speak shortly
  11. Re: OWC and FWL
    do you mean that the FWL doesn't exist in reality it's fictif concept
    Re: OWC and FWL
    The FWL does exist. In fact, the common approach of using RFT/MDT data to determined the intersection of, let's say for example, the oil and water gradients yields the position of the FWL, not the OWC as commonly believed.
