Results 1 to 6 of 6
Thread: Need reply -- very urgent please
  1. Need reply -- very urgent please
    Good day!
    A sandstone reservoir drilled and produced water free oil (100% oil & no water).
    The Avg water saturation for the tested interval is 53%* what is rest 47%?
    If reservoir is flowing only oil* then shouldn't water saturation be around 0%? why it is 53%?
    Cheers.
    Re: Need reply -- very urgent please
    hi*
    Water saturation icludes moveable and irreducible (Not moveable) water that varies with wattabillity and cappilary caracteristics of the rock (Sst in your case)* see the scal study if the rock is water wattable* the irreducible water is also inversely proportional with the pore throat size*
  5. Re: Need reply -- very urgent please
    Thanks* so what I understand from your reply is that "all the 53% water is bound (capillary or clay bound) and the reservoir is at irreducible water saturation"?
    In your case* since no water was produced at Sw=53% then the irreducible water saturation Swir is equal or higher than 53%* so that at Sw=53% the water relative permeability is 0 (krw = 0 at Sw <= Swir). PS #1: make sure your value of Sw is accurate. PS #2: this website is now including an asterisk (*) without me having typed it in. That (*) means nothing special* it is just some issue with this website.
  7. Re: Need reply -- very urgent please
    @ DAH7542* thank you replying.
    Could you please helphow to estimate the Krw and Kro?
    Thanks again ...
    Jan 2009
    ALA, KZ
    water wet resevoir or ....
    shally reservoir and incorrect resestivity interpretation...
    check m*n and water salinity
    Last Post: 09-21-2017, 06:45 PM
  2. Test Post - no reply
    By Soultongue in forum Safety And Environment
    Last Post: 02-11-2014, 10:27 AM
  3. [Urgent] ISO 599
    By minhky032003 in forum Materials Science &Corrosion
    Last Post: 03-01-2013, 08:08 AM
  4. Urgent plz!!
    By yasiobasio123 in forum Reservoir
    Last Post: 07-19-2011, 10:48 PM
