Results 1 to 7 of 7
Thread: Urgent plz!!
  1. Urgent plz!!
    Hi Friends,
    How I can find the Gas, Water and Oil gradients from Pressure-Depth plot?
    What is the method to calculate the Densities of these fluids?
    And similarly how we can determine the Capilary pressure (Pc)?
    Please reply asap, I will be very thankful.
    Cheers, Yasio
    Fluid gradients are simply the pressure change versus depth. For example, 1 gram/cc density is 0.433 psi/ft (1.42 psi/m). So on a pressure-depth plot simply choose two pints on a line and find the difference in pressure divided by the difference in depth at those two points. This is the gradient. Water should have a gradient around 0.433 psi/ft, oil around 0.3 psi/ft and gas 0.1 or so. Densities are just a conversion factor applied to these numbers to give you the density units you require. Capillary pressure can be determined from core measurements - an estimate can be got from the difference between oil water contact on logs and the free water level from formation pressure measurements.
  5. Revisar cualquier book sobre HIDROSTATICA, te sera de mucha ayuda.
    Saludos;
  6. &#201;chale una mirada:
    [link Point to another website Only the registered members can access] Saludos;
    NESTIN
    Ditto, Nestin. And if you actually feel the need for software to do this work for you, try Fekete's Validata. Contact www/feket.com and they should give you this bread-and-butter tool at a v decent price
    Sorry
    simple and free
    from RFT, XPT, FMT,etc which are pressure vs. depth
    plot pressure in x and depth in y
    get the slopes, psi/ft
    0.3 oil
    0.433 water
    gas low values, off course logs can help too, off set wells, production data
    you can search google for further info
    also you can have a look in RFT essentials slb
    hope this helps
  1. Urgent help
    Last Post: 07-08-2012, 04:31 PM
  2. urgent need
    By Islam Anas in forum Civil & Structural Engineering
    Last Post: 03-02-2012, 12:05 AM
  3. Urgent
    By asabdu in forum Geology & Exploration
    Last Post: 11-10-2010, 11:44 PM
