Thread: IEC Collection 063/150: IEC TC 23-Electrical accessories
    full list:
    IEC 60998-1:2002 Connecting devices for low-voltage circuits for household and similar purposes - Part 1: General requirements
    IEC 60998-1:2002/ISH1:2005 Interpretation sheet 1 - Connecting devices for low-voltage circuits for household and similar purposes - Part 1: General requirements
    IEC 60998-2-1:2002 Connecting devices for low-voltage circuits for household and similar purposes - Part 2-1: Particular requirements for connecting devices as separate entities with screw-type clamping units
    IEC 60998-2-2:2002 Connecting devices for low-voltage circuits for household and similar purposes - Part 2-2: Particular requirements for connecting devices as separate entities with screwless-type clamping units
    IEC 60998-2-3:2002 Connecting devices for low-voltage circuits for household and similar purposes - Part 2-3: Particular requirements for connecting devices as separate entities with insulation-piercing clamping units
    IEC 60998-2-3:2002/COR1:2006 Corrigendum 1 - Connecting devices for low-voltage circuits for household and similar purposes - Part 2-3: Particular requirements for connecting devices as separate entities with insulation-piercing clamping units
    IEC 60998-2-4:2004 Connecting devices for low-voltage circuits for household and similar purposes - Part 2-4: Particular requirements for twist-on connecting devices
    IEC 60999-1:1999 Connecting devices - Electrical copper conductors - Safety requirements for screw-type and screwless-type clamping units - Part 1: General requirements and particular requirements for clamping units for conductors from 0*2 mm2 up to 35 mm2 (included)
    IEC 61210:2010 Connecting devices - Flat quick-connect terminations for electrical copper conductors - Safety requirements
    IEC 61535:2009+AMD1:2012 CSV Installation couplers intended for permanent connection in fixedinstallations
    IEC 61535:2009 Installation couplers intended for permanent connection in fixed installations
    IEC 61535:2009/COR1:2014 Corrigendum 1 - Installation couplers intended for permanent connection in fixed installations
    IEC 61535:2009/AMD1:2012 Amendment 1 - Installation couplers intended for permanent connection in fixed installations
    IEC 61545:1996 Connecting devices - Devices for the connection of aluminium conductors in clamping units of any material and copper conductors in aluminium bodied clamping units
    IEC TR 61916:2017 Electrical accessories - Harmonization of general rules
    IEC 62080:2001+AMD1:2008+AMD2:2015 CSV Sound signalling devices for household and similar purposes
    IEC 62080:2001+AMD1:2008 CSV Sound signalling devices for household and similar purposes
    IEC 62080:2001 Sound signalling devices for household and similar purposes
    IEC 62080:2001/AMD1:2008 Amendment 1 - Sound signalling devices for household and similar purposes
    IEC 62080:2001/AMD2:2015 Amendment 2 - Sound signalling devices for household and similar purposes
    IEC TS 62735-1:2015 Direct current (DC) plugs and socket-outlets for information and communication technology (ICT) equipment installed in data centres and telecom central offices - Part 1: Plug and socket-outlet system for 2*6 kW
    IEC TS 62735-2:2016 Direct current (DC) plugs and socket-outlets for information and communication technology (ICT) equipment installed in data centres and telecom central offices - Part 2: Plug and socket-outlet system for 5*2 kW
    IEC 63044-1:2017 Home and Building Electronic Systems (HBES) and Building Automation and Control Systems (BACS) - Part 1: General requirements
    IEC 63044-3:2017 Home and Building Electronic Systems (HBES) and Building Automation and Control Systems (BACS) - Part 3: Electrical safety requirements
    IEC 63044-5-1:2017 Home and Building Electronic Systems (HBES) and Building Automation and Control Systems (BACS) - Part 5-1: EMC requirements* conditions and test set-up
    IEC 63044-5-2:2017 Home and Building Electronic Systems (HBES) and Building Automation and Control Systems (BACS) - Part 5-2: EMC requirements for HBES/BACS used in residential* commercial and light-industrial environments
    IEC 63044-5-3:2017 Home and Building Electronic Systems (HBES) and Building Automation and Control Systems (BACS) - Part 5-3: EMC requirements for HBES/BACS used in industrial environments
    the missing are:
    Re: IEC Collection 063/150: IEC TC 23-Electrical accessories
    full list 24.11.2017:
    the missing:
  1. IEC Collection 034/150: IEC TC 94-All-Or-Nothing Electrical Relays
    Last Post: 01-10-2019, 04:44 PM
  2. ISO Collection 68/300:ISO/TC 14 - Shafts for machinery and accessories
    Last Post: 11-25-2017, 07:42 AM
  3. IEC Collection 003/150:IEC TC 26:Electrical Welding
    Last Post: 11-17-2017, 03:43 AM
  4. ISO Collection 173/300:ISO TC 72-Textile machinery and accessories
    Last Post: 09-16-2017, 09:21 PM
  5. Replies: 6
    Last Post: 07-07-2017, 03:06 AM
