Thread: IEC Collection 062/150: IEC SC 17C-Assemblies
    full list:
    IEC 62271-3:2015 High-voltage switchgear and controlgear - Part 3: Digital interfaces based on IEC 61850
    IEC 62271-200:2011 High-voltage switchgear and controlgear - Part 200: AC metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to and including 52 kV
    IEC 62271-200:2011/COR1:2015 Corrigendum 1 - High-voltage swithgear and controlgear - Part 200: AC metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to and including 52 kV
    IEC 62271-201:2014 High-voltage switchgear and controlgear - Part 201: AC solid-insulation enclosed switchgear and controlgear for rated voltages above 1 kV and up to and including 52 kV
    IEC 62271-202:2014 High-voltage switchgear and controlgear - Part 202: High-voltage/ low-voltage prefabricated substation
    IEC 62271-202:2014/COR1:2015 Corrigendum 1 - High-voltage switchgear and controlgear - Part 202: High-voltage/low-voltage prefabricated substation
    IEC 62271-203:2011 High-voltage switchgear and controlgear - Part 203: Gas-insulated metal-enclosed switchgear for rated voltages above 52 kV
    IEC 62271-203:2011/COR1:2013 Corrigendum 1 - High-voltage switchgear and controlgear - Part 203: Gas-insulated metal-enclosed switchgear for rated voltages above 52 kV
    IEC 62271-204:2011 High-voltage switchgear and controlgear - Part 204: Rigid gas-insulated transmission lines for rated voltage above 52 kV
    IEC 62271-205:2008 High-voltage switchgear and controlgear - Part 205: Compact switchgear assemblies for rated voltages above 52 kV
    IEC 62271-206:2011 High-voltage switchgear and controlgear - Part 206: Voltage presence indicating systems for rated voltages above 1 kV and up to and including 52 kV
    IEC 62271-207:2012 High-voltage switchgear and controlgear - Part 207: Seismic qualification for gas-insulated switchgear assemblies for rated voltages above 52 kV
    IEC 62271-207:2012/COR1:2013 Corrigendum 1 - High-voltage switchgear and controlgear - Part 207: Seismic qualification for gas-insulated switchgear assemblies for rated voltages above 52 kV
    IEC TR 62271-208:2009 High-voltage switchgear and controlgear - Part 208: Methods to quantify the steady state* power-frequency electromagnetic fields generated by HV switchgear assemblies and HV/LV prefabricated substations
    IEC 62271-209:2007 High-voltage switchgear and controlgear - Part 209: Cable connections for gas-insulated metal-enclosed switchgear for rated voltages above 52 kV - Fluid-filled and extruded insulation cables - Fluid-filled and dry-type cable-terminations
    IEC TS 62271-210:2013 High-voltage switchgear and controlgear - Part 210: Seismic qualification for metal enclosed and solid-insulation enclosed switchgear and controlgear assemblies for rated voltages above 1 kV and up to and including 52 kV
    IEC 62271-211:2014 High-voltage switchgear and controlgear - Part 211: Direct connection between power transformers and gas-insulated metal-enclosed switchgear for rated voltages above 52 kV
    IEC 62271-211:2014/COR1:2015 Corrigendum 1 - High-voltage switchgear and controlgear - Part 211: Direct connection between power transformers and gas-insulated metal-enclosed switchgear for rated voltages above 52 kV
    IEC 62271-211:2014/COR2:2017 Corrigendum 2 - High-voltage switchgear and controlgear - Part 211: Direct connection between power transformers and gas-insulated metal-enclosed switchgear for rated voltages above 52 kV
    IEC 62271-212:2016 High-voltage switchgear and controlgear - Part 212: Compact Equipment Assembly for Distribution Substation (CEADS)
    IEC TS 62271-304:2008 High-voltage switchgear and controlgear - Part 304: Design classes for indoor enclosed switchgear and controlgear for rated voltages above 1 kV up to and includuing 52 kV to be used in severe climatic conditions
    IEC TS 62271-304:2008/COR1:2010 Corrigendum 1 - High-voltage switchgear and controlgear - Part 304: Design classes for indoor enclosed switchgear and controlgear for rated voltages above 1 kV up to and including 52 kV to be used in severe climatic conditions
    IEC TR 62271-307:2015 High-voltage switchgear and controlgear - Part 307: Guidance for the extension of validity of type tests of AC metal and solid-insulation enclosed switchgear and controlgear for rated voltages above 1 kV and up to and including 52 kV
    the missing is:
    Re: IEC Collection 062/150: IEC SC 17C-Assemblies
    full list 24.11.2017:
    complete
  1. Subsurface Sucker Rod Pump Assemblies, Components, and Fittings
    By Marty Thompson in forum Drilling And Workover
    Last Post: 02-13-2019, 03:24 AM
  2. Replies: 0
    Last Post: 08-25-2015, 11:19 AM
  3. Interfacial supramolecular assemblies 2003 - Forster & Keyes
    By dongono in forum General Engineering
    Last Post: 02-27-2015, 04:44 AM
  4. Low-voltage switchgear and controlgear assemblies
    By Ahmed Mokni in forum ÇáÊÑÈíÉ æÇáÊäãíÉ ÇáÈÔÑíÉ
    Last Post: 08-01-2013, 08:13 PM
