ISO TC 4 STANDARDS
ISO 15:2017 Rolling bearings -- Radial bearings -- Boundary dimensions* general plan
ISO 104:2015 Rolling bearings -- Thrust bearings -- Boundary dimensions* general plan
ISO 113:2010 Rolling bearings -- Plummer block housings -- Boundary dimensions
ISO 2982-1:2013 Rolling bearings -- Accessories -- Part 1: Dimensions for adapter sleeve assemblies and withdrawal sleeves
ISO 2982-2:2013 Rolling bearings -- Accessories -- Part 2: Dimensions for locknuts and locking devices
ISO 5593:1997 Rolling bearings -- Vocabulary
ISO 5593:1997/Amd 1:2007 Rolling bearings -- Vocabulary
ISO 15241:2012 Rolling bearings -- Symbols for physical quantities
ISO 15242-1:2015 Rolling bearings -- Measuring methods for vibration -- Part 1: Fundamentals
ISO 15242-2:2015 Rolling bearings -- Measuring methods for vibration -- Part 2: Radial ball bearings with cylindrical bore and outside surface
ISO 15242-3:2017 Rolling bearings -- Measuring methods for vibration -- Part 3: Radial spherical and tapered roller bearings with cylindrical bore and outside surface
ISO 15242-4:2007 Rolling bearings -- Measuring methods for vibration -- Part 4: Radial cylindrical roller bearings with cylindrical bore and outside surface
ISO 15243:2017 Rolling bearings -- Damage and failures -- Terms* characteristics and causes
ISO 21107:2015 Rolling bearings and spherical plain bearings -- Search structure for electronic media -- Characteristics and performance criteria identified by property vocabulary
ISO/TS 23768-1:2011 Rolling bearings -- Parts library -- Part 1: Reference dictionary for rolling bearings
Tolerances* tolerance definitions and symbols (including GPS)
ISO 199:2014 Rolling bearings -- Thrust bearings -- Geometrical product specification (GPS) and tolerance values
ISO 464:2015 Rolling bearings -- Radial bearings with locating snap ring -- Dimensions* geometrical product specifications (GPS) and tolerance values
ISO 492:2014 Rolling bearings -- Radial bearings -- Geometrical product specifications (GPS) and tolerance values
ISO 582:1995 Rolling bearings -- Chamfer dimensions -- Maximum values
ISO 582:1995/Amd 1:2013 Rolling bearings -- Chamfer dimensions -- Maximum values
ISO 1132-1:2000 Rolling bearings -- Tolerances -- Part 1: Terms and definitions
ISO 1132-2:2001 Rolling bearings -- Tolerances -- Part 2: Measuring and gauging principles and methods
ISO 1224-1:2007 Rolling bearings -- Instrument precision bearings -- Part 1: Boundary dimensions* tolerances and characteristics of metric series bearings
ISO 1224-2:2007 Rolling bearings -- Instrument precision bearings -- Part 2: Boundary dimensions* tolerances and characteristics of inch series bearings
ISO 5753-1:2009 Rolling bearings -- Internal clearance -- Part 1: Radial internal clearance for radial bearings
ISO 5753-2:2010 Rolling bearings -- Internal clearance -- Part 2: Axial internal clearance for four-point-contact ball bearings
Needle* cylindrical and spherical roller bearings
ISO 246:2007 Rolling bearings -- Cylindrical roller bearings* separate thrust collars -- Boundary dimensions
ISO 1206:2001 Rolling bearings -- Needle roller bearings* dimension series 48* 49 and 69 -- Boundary dimensions and tolerances
ISO 1206:2001/Amd 1:2013 Tolerances for shaft raceway
ISO 3030:2011 Rolling bearings -- Radial needle roller and cage assemblies -- Boundary dimensions and tolerances
ISO 3031:2000 Rolling bearings -- Thrust needle roller and cage assemblies* thrust washers -- Boundary dimensions and tolerances
ISO 3096:1996 Rolling bearings -- Needle rollers -- Dimensions and tolerances
ISO 3096:1996/Cor 1:1999 Rolling bearings -- Needle rollers -- Dimensions and tolerances
ISO 3245:2015 Boundary dimensions* geometrical product specifications (GPS) and tolerance values
ISO 7063:2003 Rolling bearings -- Needle roller bearing track rollers -- Boundary dimensions and tolerances
ISO 12043:2007 Rolling bearings -- Single-row cylindrical roller bearings -- Chamfer dimensions for loose rib and non-rib sides
ISO 12297:2012 Rolling bearings -- Steel cylindrical rollers -- Dimensions and tolerances
Insert bearings
ISO 3228:2013 Rolling bearings -- Cast and pressed housings for insert bearings -- Boundary dimensions and tolerances
ISO 9628:2006 Rolling bearings -- Insert bearings and eccentric locking collars -- Boundary dimensions and tolerances
ISO 9628:2006/Amd 1:2011 Diameter series 3
Spherical plain bearings
ISO 6811:1998 Spherical plain bearings -- Vocabulary
ISO 6811:1998/Cor 1:1999 Spherical plain bearings -- Vocabulary
ISO 12240-1:1998 Spherical plain bearings -- Part 1: Radial spherical plain bearings
ISO 12240-2:1998 Spherical plain bearings -- Part 2: Angular contact radial spherical plain bearings
ISO 12240-3:1998 Spherical plain bearings -- Part 3: Thrust spherical plain bearings
ISO 12240-4:1998 Spherical plain bearings -- Part 4: Spherical plain bearing rod ends
ISO 12240-4:1998/Cor 1:1999 Spherical plain bearings -- Part 4: Spherical plain bearing rod ends
Load ratings and life
ISO 76:2006 Rolling bearings -- Static load ratings
ISO 281:2007 Rolling bearings -- Dynamic load ratings and rating life
ISO/TR 1281-1:2008 Rolling bearings -- Explanatory notes on ISO 281 -- Part 1: Basic dynamic load rating and basic rating life
ISO/TR 1281-1:2008/Cor 1:2009 Rolling bearings -- Explanatory notes on ISO 281 -- Part 1: Basic dynamic load rating and basic rating life
ISO/TR 1281-2:2008 Rolling bearings -- Explanatory notes on ISO 281 -- Part 2: Modified rating life calculation* based on a systems approach to fatigue stresses
ISO/TR 1281-2:2008/Cor 1:2009 Rolling bearings -- Explanatory notes on ISO 281 -- Part 2: Modified rating life calculation* based on a systems approach to fatigue stresses
ISO/TR 10657:1991 Explanatory notes on ISO 76
ISO 14728-1:2017 Rolling bearings -- Linear motion rolling bearings -- Part 1: Dynamic load ratings and rating life
ISO 14728-2:2017 Rolling bearings -- Linear motion rolling bearings -- Part 2: Static load ratings
ISO 15312:2003 Rolling bearings -- Thermal speed rating -- Calculation and coefficients
ISO/TS 16281:2008 Rolling bearings -- Methods for calculating the modified reference rating life for universally loaded bearings
ISO/TS 16281:2008/Cor 1:2009 Rolling bearings -- Methods for calculating the modified reference rating life for universally loaded bearings
ISO 20015:2017 Spherical plain bearings -- Method for the calculation of static and dynamic load ratings
Tapered roller bearings
ISO 355:2007 Rolling bearings -- Tapered roller bearings -- Boundary dimensions and series designations
ISO 355:2007/Amd 1:2012 Rolling bearings -- Tapered roller bearings -- Boundary dimensions and series designations
ISO 10317:2008 Rolling bearings -- Tapered roller bearings -- Designation system
ISO 10317:2008/Amd 1:2013 Design variant designation and comparison of tolerance class designations for single-row tapered roller bearings
ISO 10285:2007 Rolling bearings -- Sleeve type linear ball bearings -- Boundary dimensions and tolerances
ISO 10285:2007/Amd 1:2012 Rolling bearings -- Sleeve type linear ball bearings -- Boundary dimensions and tolerances
ISO 12090-1:2011 Rolling bearings -- Profiled rail guides for linear motion rolling bearings -- Part 1: Boundary dimensions and tolerances for series 1* 2 and 3
ISO 12090-2:2011 Rolling bearings -- Profiled rail guides for linear motion rolling bearings -- Part 2: Boundary dimensions and tolerances for series 4 and 5
ISO 13012-1:2009 Rolling bearings -- Accessories for sleeve type linear ball bearings -- Part 1: Boundary dimensions and tolerances for series 1 and 3
ISO 13012-2:2009 Rolling bearings -- Accessories for sleeve type linear ball bearings -- Part 2: Boundary dimensions and tolerances for series 5
ISO 24393:2008 Rolling bearings -- Linear motion rolling bearings -- Vocabulary
Ball bearings
ISO 3290-1:2014 Rolling bearings -- Balls -- Part 1: Steel balls
ISO 3290-2:2014 Rolling bearings -- Balls -- Part 2: Ceramic balls
ISO 8443:2010 Rolling bearings -- Radial ball bearings with flanged outer ring -- Flange dimensions
ISO 12044:2014 Rolling bearings -- Single-row angular contact ball bearings -- Chamfer dimensions for outer ring non-thrust side
ISO 20515:2012 Rolling bearings -- Radial bearings* retaining slots -- Dimensions and tolerances
ISO 20516:2007 Rolling bearings -- Aligning thrust ball bearings and aligning seat washers -- Boundary dimensions
missing are:
