ISO TC/123 STANDARDS
ISO 7902-1:2013 Hydrodynamic plain journal bearings under steady-state conditions -- Circular cylindrical bearings -- Part 1: Calculation procedure
ISO 7902-2:1998 Hydrodynamic plain journal bearings under steady-state conditions -- Circular cylindrical bearings -- Part 2: Functions used in the calculation procedure
ISO 7902-3:1998 Hydrodynamic plain journal bearings under steady-state conditions -- Circular cylindrical bearings -- Part 3: Permissible operational parameters
ISO 12130-1:2001 Plain bearings -- Hydrodynamic plain tilting pad thrust bearings under steady-state conditions -- Part 1: Calculation of tilting pad thrust bearings
ISO 12130-2:2013 Plain bearings -- Hydrodynamic plain tilting pad thrust bearings under steady-state conditions -- Part 2: Functions for calculation of tilting pad thrust bearings
ISO 12130-3:2001 Plain bearings -- Hydrodynamic plain tilting pad thrust bearings under steady-state conditions -- Part 3: Guide values for the calculation of tilting pad thrust bearings
ISO 12131-1:2001 Plain bearings -- Hydrodynamic plain thrust pad bearings under steady-state conditions -- Part 1: Calculation of thrust pad bearings
ISO 12131-2:2016 Plain bearings -- Hydrodynamic plain thrust pad bearings under steady-state conditions -- Part 2: Functions for the calculation of thrust pad bearings
ISO 12131-3:2001 Plain bearings -- Hydrodynamic plain thrust pad bearings under steady-state conditions -- Part 3: Guide values for the calculation of thrust pad bearings
ISO 12167-1:2016 Plain bearings -- Hydrostatic plain journal bearings with drainage grooves under steady-state conditions -- Part 1: Calculation of oil-lubricated plain journal bearings with drainage grooves
ISO 12167-2:2001 Plain bearings -- Hydrostatic plain journal bearings with drainage grooves under steady-state conditions -- Part 2: Characteristic values for the calculation of oil-lubricated plain journal bearings with drainage grooves
ISO 12168-1:2001 Plain bearings -- Hydrostatic plain journal bearings without drainage grooves under steady-state conditions -- Part 1: Calculation of oil-lubricated plain journal bearings without drainage grooves
ISO 12168-2:2001 Plain bearings -- Hydrostatic plain journal bearings without drainage grooves under steady-state conditions -- Part 2: Characteristic values for the calculation of oil-lubricated plain journal bearings without drainage grooves
Materials and lubricants* their properties* characteristics* test methods and testing conditions
ISO 4381:2011 Plain bearings -- Tin casting alloys for multilayer plain bearings
ISO 4382-1:1991 Plain bearings -- Copper alloys -- Part 1: Cast copper alloys for solid and multilayer thick-walled plain bearings
ISO 4382-2:1991 Plain bearings -- Copper alloys -- Part 2: Wrought copper alloys for solid plain bearings
ISO 4383:2012 Plain bearings -- Multilayer materials for thin-walled plain bearings
ISO 4384-1:2012 Plain bearings -- Hardness testing of bearing metals -- Part 1: Multilayer bearings materials
ISO 4384-2:2011 Plain bearings -- Hardness testing of bearing metals -- Part 2: Solid materials
ISO 4385:1981 Plain bearings -- Compression testing of metallic bearing materials
ISO 4386-1:2012 Plain bearings -- Metallic multilayer plain bearings -- Part 1: Non-destructive ultrasonic testing of bond of thickness greater than or equal to 0*5 mm
ISO 4386-2:2012 Plain bearings -- Metallic multilayer plain bearings -- Part 2: Destructive testing of bond for bearing metal layer thicknesses greater than or equal to 2 mm
ISO 4386-3:1992 Plain bearings -- Metallic multilayer plain bearings -- Part 3: Non-destructive penetrant testing
ISO 6279:2017 Plain bearings -- Aluminium alloys for solid bearings
ISO 6280:1981 Plain bearings -- Requirements on backings for thick-walled multilayer bearings
ISO 6281:2007 Plain bearings -- Testing under conditions of hydrodynamic and mixed lubrication in test rigs
ISO 6282:1983 Plain bearings -- Metallic thin-walled half bearings -- Determination of the sigma 0*01*-limit
ISO 6691:2000 Thermoplastic polymers for plain bearings -- Classification and designation
ISO 7146-1:2008 Plain bearings -- Appearance and characterization of damage to metallic hydrodynamic bearings -- Part 1: General
ISO 7146-2:2008 Plain bearings -- Appearance and characterization of damage to metallic hydrodynamic bearings -- Part 2: Cavitation erosion and its countermeasures
ISO 7148-1:2012 Plain bearings -- Testing of the tribological behaviour of bearing materials -- Part 1: Testing of bearing metals
ISO 7148-2:2012 Plain bearings -- Testing of the tribological behaviour of bearing materials -- Part 2: Testing of polymer-based bearing materials
ISO 7905-1:1995 Plain bearings -- Bearing fatigue -- Part 1: Plain bearings in test rigs and in applications under conditions of hydrodynamic lubrication
ISO 7905-2:1995 Plain bearings -- Bearing fatigue -- Part 2: Test with a cylindrical specimen of a metallic bearing material
ISO 7905-3:1995 Plain bearings -- Bearing fatigue -- Part 3: Test on plain strips of a metallic multilayer bearing material
ISO 7905-4:1995 Plain bearings -- Bearing fatigue -- Part 4: Tests on half-bearings of a metallic multilayer bearing material
ISO 10129:2017 Plain bearings -- Testing of bearing metals -- Resistance to corrosion by lubricants under static conditions
Dimensions* tolerances and construction details
ISO 3547-1:2006 Plain bearings -- Wrapped bushes -- Part 1: Dimensions
ISO 3547-2:2017 Plain bearings -- Wrapped bushes -- Part 2: Test data for outside and inside diameters
ISO 3547-3:2017 Plain bearings -- Wrapped bushes -- Part 3: Lubrication holes* grooves and indentations
ISO 3547-4:2017 Plain bearings -- Wrapped bushes -- Part 4: Materials
ISO 3548-1:2014 Plain bearings -- Thin-walled half bearings with or without flange -- Part 1: Tolerances* design features and methods of test
ISO 4379:1993 Plain bearings -- Copper alloy bushes
ISO 6525:1983 Plain bearings -- Ring type thrust washers made from strip -- Dimensions and tolerances
ISO 6526:1983 Plain bearings -- Pressed bimetallic half thrust washers -- Features and tolerances
ISO 11687-1:1995 Plain bearings -- Pedestal plain bearings -- Part 1: Pillow blocks
ISO 11687-2:1995 Plain bearings -- Pedestal plain bearings -- Part 2: Side flange bearings
ISO 11687-3:1995 Plain bearings -- Pedestal plain bearings -- Part 3: Centre flange bearings
ISO 12128:2001 Plain bearings -- Lubrication holes* grooves and pockets -- Dimensions* types* designation and their application to bearing bushes
ISO 12129-1:1995 Plain bearings -- Part 1: Fits
ISO 12129-2:1995 Plain bearings -- Part 2: Tolerances on form and position and surface roughness for shafts* flanges and thrust collars
ISO/TR 27507:2010 Plain bearings -- Recommendations for automotive crankshaft bearing environments
Quality analysis and assurance
ISO 3547-5:2007 Plain bearings -- Wrapped bushes -- Part 5: Checking the outside diameter
ISO 3547-6:2007 Plain bearings -- Wrapped bushes -- Part 6: Checking the inside diameter
ISO 3547-7:2007 Plain bearings -- Wrapped bushes -- Part 7: Measurement of wall thickness of thin-walled bushes
ISO 3548-2:2009 Plain bearings -- Thin-walled half bearings with or without flange -- Part 2: Measurement of wall thickness and flange thickness
ISO 3548-3:2012 Plain bearings -- Thin-walled half bearings with or without flange -- Part 3: Measurement of peripheral length
ISO 12132:2017 Plain bearings -- Quality assurance of thin-walled half bearings -- Design FMEA
ISO 12301:2007 Plain bearings -- Quality control techniques and inspection of geometrical and material quality characteristics
ISO 12302:2017 Plain bearings -- Quality characteristics -- Statistical process control (SPC)
ISO 12303:1995 Plain bearings -- Quality characteristics -- Calculation of machine and process capabilities
ISO 12308:2017 Plain bearings -- Quality assurance -- Sample types -- Definitions* applications and testing
ISO 13778:2017 Plain bearings -- Quality assurance of thin-walled half bearings -- Selective assembly of bearings to achieve a narrow clearance range
Terms and common items
ISO 4378-1:2017 Plain bearings -- Terms* definitions* classification and symbols -- Part 1: Design* bearing materials and their properties
ISO 4378-2:2017 Plain bearings -- Terms* definitions* classification and symbols -- Part 2: Friction and wear
ISO 4378-3:2017 Plain bearings -- Terms* definitions* classification and symbols -- Part 3: Lubrication
ISO 4378-4:2009 Plain bearings -- Terms* definitions* classification and symbols -- Part 4: Basic symbols
ISO 4378-5:2009 Plain bearings -- Terms* definitions* classification and symbols -- Part 5: Application of symbols
ISO/TR 4378-6:2012 Plain bearings -- Terms* definitions* classification and symbols -- Part 6: Abbreviated terms
Special types of plain bearings
ISO 2795:2014 Plain bearings -- Sintered bushes -- Dimensions and tolerances
ISO 13939:2012 Foil bearings -- Guidelines for testing of the performance of foil journal bearings --Testing of load capacity* friction coefficient and lifetime
ISO 14287:2012 Plain bearings -- Pad materials for tilting pad bearings
ISO 16287:2005 Plain bearings -- Thermoplastic bushes -- Dimensions and tolerances
ISO/TR 17606:2014 Plain bearings -- Lubrication characteristics of crosshead pin bearings for low-speed marine diesel engines
ISO 19259:2015 Plain bearings -- Bearings with embedded solid lubricants
ISO 20054:2016 Plain bearings -- Bearings containing dispersed solid lubricants
the missing are;
