Hi*
I was searching for a while to understand voltage drop calculation for overhead lines as per IEC* but as far as I found any relevant information in IEC 60364-5-52 describes in general* where reactance and resistance are predetermined or supplied by the manufacturer. But reactance in cables can be pre-calculated where as for overhead lines it varies with the distance between phases and other parameters.
So* I request anyone who share their experience on the same. I would appreciate any input other than that is referred to ANSI/NEC or any 60 Hz frequency related standards (as they are not being practiced in the place where I work ).
thanks in advance.
kalinath.
