Results 1 to 1 of 1
Thread: Calculate pressure drop in steam distribution pipe lines
    The pressure drop in saturated steam distribution pipes can be calculated in metric units as
    dp = 0.6753 106 q2 l (1 + 91.4/d) / ρ d5 (1)
    where
    dp = pressure drop (Pa)
    q = steam flow rate (kg/h)
    l = length of pipe (m)
    d = pipe inside diameter (mm)
    ρ = steam density (kg/m3)
    Note that the pressure drop calculated might be higher than the actual values at higher velocities.
    The Unwin formula can also be expressed in imperial units as
    dp = 0.0001306 q2 l (1 + 3.6/d) / (3600 ρ d5)(2)
    where
    dp = pressure drop (psi)
    q = steam flow rate (lb/hr)
    l = length of pipe (ft)
    d = pipe inside diameter (inches)
    ρ = steam density (lb/ft3)
    [h=Example - Pressure Drop in Steam Pipe]3[/h] Steam, 4000 kg/h at 10 bar (1000 kPa) pressure with density 5.15 kg/m3 flows through a schedule 40, ND 100 steel pipe, inside diameter 102 mm and length 100 m. The pressure drop can be calculated as
    dp = 0.6753 106 (4000 kg/h)2 (100 m) (1 + 91.4/(102 mm)) / ((5.15 kg/m3) (102 mm)5 )
    = 36030 Pa
    = 36 kPa
  1. How to calculate Well Bore pressure drop?
    By ibtisam01 in forum Reservoir
    Last Post: 11-27-2013, 11:44 PM
  2. Article: Re: How to calculate Well Bore pressure drop?
    By DAH7542 in forum Home Articles
    Last Post: 11-26-2013, 12:31 AM
  3. Replies: 0
    Last Post: 07-26-2011, 04:43 PM
  4. Superheated steam pipe line pressure drop estimate
    By A.Venugopal in forum Pipeline And Fluid Flow
    Last Post: 03-19-2010, 05:47 PM
